Wont Burn Program to 16F690 Chip
JDR04
Has thanked: 111 times
Been thanked: 13 times
Post by JDR04 »
Hello all. Cant seem to burn my program to the 16F690 chip. Compiles to C and Hex all OK.
I have attached a screen grab of the error message and also of my chip settings. Hopefully somebody will spot my mistake.
Thanks a lot folks...........John
IRTRIGGER.fcf
(16 KiB) Downloaded 274 times
NEW CHIP CONFIG SETTINGS2.jpg (61.73 KiB) Viewed 4007 times
Burn To Chip Error2.jpg (44.5 KiB) Viewed 4007 times
Re: Wont Burn Program to 16F690 Chip
Hi John,
The usual cause of the error messag eyou can see are poor connections between Programmer and microcontroller.
Or there is a cap between programming connections and ground.
Have you got a circuit diagram?
You can check voltage are correct at each programming pin, by using the Pickit2 standalone programming software and going to Tools, Troubleshoot....
JDR04
Post by JDR04 »
Ok I'll see if I can do that and do another post........Thanks John
JDR04
Post by JDR04 »
Hi Martin, it looks like something has gone wrong with my PICkit2 programmer. I think its software so I'll reinstall it tomorrow and let you guys know what happens..
Thanks for your time..John
