Error when trying to program some values in internal EEPROM
Crenwick
Has thanked: 7 times
Been thanked: 21 times
Post by Crenwick »
Hi all,
I'm testing some RGB curves for my project and made a simple program to test these curves (see attach). Problem is when I try to write the values in EEPROM at programming.
I added some values to the EEPROM via the "supplementary code" option.
I changed also the #pragma DATA _EEPROM to #pragma DATA 0xF000 like explained in the topic here under:
http://www.matrixmultimedia.com/mmforum ... rom#p56956
Here is the error :
Does someone already tested to write some data to data_EEPROM with mloader ?
When I disable the extra code it programs the PIC fine but without code in EEPROM ...
Ramptest.fcfx
(6.63 KiB) Downloaded 256 times
Bernard
Flowcode 6 / EB006-V9
Crenwick
Re: Error when trying to program some values in internal EEP
Post by Crenwick »
Some update !
I used the ramptest.hex with my pickit2 and it was programmed successfully !
So I presume we have a problem with mloader and/or EB006V9 :(
Bernard
