Writing values in internal EEPROM (SOLVED)
Crenwick
Has thanked: 7 times
Been thanked: 21 times
Post by Crenwick »
Hello all,
Is there a limitation in the number of values to write to internal EEPROM at once ?
I have 250 values to write
0, 0, 0, 0, 0, 1, 1, 1, 2, 2, 3, 3, 4, 4, 5, 6, 7, 8, 8, 9, 10, 11, 13, 14, 15, 16, 18, 19, 20, 22, 23, 25, 27, 28, 30, 32, 34, 36, 38, 40, 42, 44, 46, 48, 50, 53, 55, 57, 60, 62, 65, 68, 70, 73, 76, 79, 82, 85, 88, 91, 94, 97, 100, 103, 107, 110, 113, 117, 120, 124, 127, 131, 135, 139, 142, 146, 150, 154, 158, 162, 167, 171, 175, 179, 184, 188, 192, 197, 201, 206, 211, 215, 220, 225, 230, 235, 240, 245, 250, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 0, 0, 0, 0, 0, 8, 31, 100, 96, 100, 0, 0, 0, 0, 0, 4, 5, 57, 100, 87, 0, 8, 15, 20, 25, 35, 5, 1, 1, 85, 100, 95, 100, 81, 0, 0, 0, 0, 0, 0, 87, 100, 57, 5, 16, 13, 5, 0, 0, 0, 85, 1, 1, 5, 48, 38, 28, 17, 8, 0
But after compiling only a few (and not the good one) are written.
Here is a little program I made to test
Flowcode1.fcfx
(4.79 KiB) Downloaded 272 times
Bernard
Flowcode 6 / EB006-V9
Re: Writing values in internal EEPROM
Hello Bernard,
Looking at the C code these are the values that are being set.
#ifdef MX_CAL_PIC
#pragma DATA _EEPROM, 0,0,0,0,0,1,1,1,2,2,3,3,4,4,5,6,7,8,8,9,10,11,13,14,15,16,18
#endif
Which is nothing like what it should be. I'll have a dig into the component now and see if I can work out why this is failing.
I think I have now fixed the problem, it seemed the EEPROM component had a cap on how many characters were in the initialiser string so I have now upped this to 1000 characters which seems to be making it work through to the C correctly.
eeprom.fcpx
(18.07 KiB) Downloaded 297 times
#ifdef MX_CAL_PIC
#pragma DATA _EEPROM, 0,0,0,0,0,1,1,1,2,2,3,3,4,4,5,6,7,8,8,9,10,11,13,14,15,16,18,19,20,22,23,25,27,28,30,32,34,36,38,40,42,44,46,48,50,53,55,57,60,62,65,68,70,73,76,79,82,85,88,91,94,97,100,103,107,110,113,117,120,124,127,131,135,139,142,146,150,154,158,162,167,171,175,179,184,188,192,197,201,206,211,215,220,225,230,235,240,245,250,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,0,0,0,0,0,8,31,100,96,100,0,0,0,0,0,4,5,57,100,87,0,8,15,20,25,35,5,1,1,85,100,95,100,81,0,0,0,0,0,0,87,100,57,5,16,13,5,0,0,0,85,1,1,5,48,38,28,17,8,0
#endif
Let me know how you get on.
Crenwick
Post by Crenwick »
PERFECT !
That's great & fast service Ben !
Many thank's,
PS : Tested and working :wink:
Bernard
