I have successfully set up the servo component.
On another project I have successfully used the PWM component.
Trying the two together seems to stop either working properly.
I therefor though of using a clock to provide the PWM. This has the servo jumping all over the place, whichever clock I use.
Please suggest a strategy to enable me to use a servo and PWM (in some form).
It would also be useful to know what resources the servo component uses.
The chip used is a 16F887 using the internal clock.
Servo is on RD2.
The PWM was to be on RD1 but the attached code just looks at the clock effect.
I am using v6.0.7.0.
Thanks.
Servo and Clock or PWM
Mark
- Has thanked: 20 times
- Been thanked: 16 times
- ServoandClock1.fcfx
- Servo and Clock
- (14.78 KiB) Downloaded 295 times
Go with the Flow.
Re: Servo and Clock or PWM
Hi Mark, have you see this thread?
There are a few posts, but don't forget to checkout the flowchart on the last page.
The Servo component utilises the Timer 1 peripheral and the Capture Compare CCP peripheral, as does the PWM component.
So you can either generate the servo signals using the timer 0 interrupt as Martin showed or you can generate the PWM using software techniques and the timer 0 interrupt.
An example of software PWM can be found here, http://www.flowcode.co.uk/article.php?a=52
