I have had a look at the excellent wiki
(and trawled the Forum, so sorry if it already there).
http://www.flowcode.co.uk/wiki/index.php ... ming_Tools
and at the microchip datasheet (attached).
From this I expected changing, the FC 6 Programmer Parameters to:
-P$(chip) -F$(target).hex -E -M -V5.000
would give 5v power, no luck FC gives error 5 (vs error 2 for unpowered).
How can I power the PicKit3 when using FC6?
Thanks.
ps I'm using windows 7, 64 bit
PicKit3 Command Line Extensions - Power
Mark
- Has thanked: 20 times
- Been thanked: 16 times
- PicKit3 Command Line.txt
- (12.91 KiB) Downloaded 364 times
Go with the Flow.
Re: PicKit3 Command Line Extensions - Power
Hi Mark,
Thanks for the detailed post
Makes my job much easier.
You could try these to see if they make any difference.
-P$(chip) -F$(target).hex -E -M -V5.0 -I
Let me know how you get on.
I seem to remember a niggle with the powering of the PICkit 3 but not sure if it ever got solved. From memory Microchip said they had intentionally added it because the PICkit 2 had damaged some hardware but I never had any problems with it.
Mark
Hi Ben,
Thanks for the fast response; adding
-V5.0 works.
For reference, at the Build - Compiler Options - Programmer entry we need:
Location
...D:\Flowcodev6\tools\PICkit3\PK3CMD.exe (or whatever the system needs)
Parameters
To cut a long story short I also tried several chips and the 'proof' came from a known good circuit with a known good program. Some other combinations gave other errors.
A list of what the error codes for FCv6 mean may be useful for future reference.
Mark
-V5.0 works.
Location
Parameters
Mark
Go with the Flow.
