Gyroscope L3G4200D
hypamat
Has thanked: 6 times
Been thanked: 18 times
Gyroscope L3G4200D
Post by hypamat »
hey guys,
sorry to keep asking questions, but I'm a bit of a "newbie" i am trying to get the gyroscope to work, but i can't get it to read it properly in the simulation. i have got the gyroscope and a LCD screen on the components window, and i just want to read the Y axis for now, but all it shows is zero, even if i adjust the inputs in the simulation. Along with this not working, it concerned me that it only showed a whole number, not (for example) 27.6 is there a way to do this, too?
thanks for your help,
Matt
kersing
Has thanked: 553 times
Been thanked: 1081 times
Re: Gyroscope L3G4200D
Post by kersing »
It helps if you post your program source so we can take a look and try to find what is wrong with it. Now there is not a lot to go on...
(To attach a flow code file, choose the 'Upload attachment' TAB below the 'Save', 'Preview' and 'Submit' buttons. Browse to the file and click on 'Add the file')
― C.S. Lewis
hypamat
Post by hypamat »
ah, that would help! I've attached my fcfx file now, please let me know what you think :)
thanks!
Gyroscope.fcfx
(5.27 KiB) Downloaded 391 times
Hi Matt,
Just before GetY(), Try placing A Gyroscope SampleDevice().
Also don't forget, before compiling to hex you will need a Gyroscope Initialise at the start of main.
hypamat
Post by hypamat »
brilliant! simple if you know how, eh?
thanks again, working perfectly now :)
matt
you're welcome Matt,
Glad its working now.
Thanks for letting us know.
hypamat
Post by hypamat »
Just to close this topic, i have finished my flow code file and would like to share it as a example for others reading :) it checks to make sure the communication to the device is working properly, and then gives you a x, y and z reading from the sensor and displays that on a LCD screen, useful to build on :)
Thanks again,
matt
Gyroscope.fcfx
(10.19 KiB) Downloaded 407 times
George_B
Has thanked: 51 times
Been thanked: 19 times
Post by George_B »
Hello, I was trying to communicate with a gyro module MPU-6050 but i was unable to do so. I think the two versions have a different controlled technique?
Any idea of how i can get some data out of this module?
http://www.ebay.co.uk/itm/MPU-6050-Modu ... 2315263503
EDIT: I found this topic after some search that did not came up with the first shot. Here it is
George
