problem with WIZNET WIZ550io instead of WIZ810MJ
For anyone wishing to receive additional help with a project or simply looking to hire an embedded contractor we have a few contacts who would be more then willing to help.
Frank
Post by Frank »
Dear,
I'm trying to connect a WIZ550io with W5500 from WIZNET to a PIC controller, using flowcode V5.5
I have connected it via the ISP connections, just like you do for the WIZ810MJ on the EB023 V2 board.
The only differents is that I use resistors in stead of a MAX3002 for level shifting from 5V to 3.3V (I know that this should work from an other project).
I have downloaded the easy_web server application into the PIC18F4455 controller from a FFrobot (see attached).
When I connect the WIZNET module via a crossed UTP cable to my laptop, and I do a ping instruction in the command prompt line to the default 196.168.1.2 I still have no connection. I can also not look via explorer to the webpages on the same IP adres.
I disconnected my wireless internet connection while trying to setup connection via the ethernet port.
Can you help me out with this problem?
thanks in advanced.
Frank Marchal
01_EASY_WEBSERVER.fcf
easy webserver code with modifications for the FFrobot.
(18.66 KiB) Downloaded 872 times
