AVR 1284p Error
JohnCrow
Has thanked: 364 times
Been thanked: 716 times
AVR 1284p Error
Post by JohnCrow »
Ive just tried programming an AVR 1284P device with the following error
(though it will compile to hex ok)
Target folder: H:\FLOWCO~1\PROJEC~1
Source name: H:\Flowcode 6 Projects\Projects FC6 AVR\LED Flash.fcfx
Title:
Description:
Device: AVR.ATMEGA.ATMEGA1284P
Generated by: Flowcode v6.0.10.0
Date: Sunday, August 03, 2014 16:17:54
Users: 1
Registered to: JohnCrow
Licence key: HRKH69
NOT FOR COMMERCIAL USE
http://www.flowcode.co.uk
Launching the compiler...
C:\Program Files (x86)\Matrix Multimedia\Flowcode V6\compilers\avr\batchfiles\avra.bat atmega1284p "H:\FLOWCO~1\PROJEC~1\LED Flash.elf" "H:\FLOWCO~1\PROJEC~1\LED Flash.c" "H:\FLOWCO~1\PROJEC~1\LED Flash.lst"
Launching compiler...
H:\FLOWCO~1\PROJEC~1>"C:\PROGRA~2\MATRIX~1\FL7431~1\COMPIL~1\avr\BATCHF~1\..\bin\avr-gcc.exe" -mmcu=atmega1284p -Os -funsigned-char -o "H:\FLOWCO~1\PROJEC~1\LED Flash.elf" "H:\FLOWCO~1\PROJEC~1\LED Flash.c" -lm
H:\FLOWCO~1\PROJEC~1>"C:\PROGRA~2\MATRIX~1\FL7431~1\COMPIL~1\avr\BATCHF~1\..\bin\avr-objdump.exe" -S "H:\FLOWCO~1\PROJEC~1\LED Flash.elf" 1>"H:\FLOWCO~1\PROJEC~1\LED Flash.lst"
H:\FLOWCO~1\PROJEC~1>"C:\PROGRA~2\MATRIX~1\FL7431~1\COMPIL~1\avr\BATCHF~1\..\bin\avr-size.exe" -B -d "H:\FLOWCO~1\PROJEC~1\LED Flash.elf"
text data bss dec hex filename
792 0 22 814 32e H:\FLOWCO~1\PROJEC~1\LED Flash.elf
Compilation successful!
Completed compilation, return = 0
C:\Program Files (x86)\Matrix Multimedia\Flowcode V6\compilers\avr\batchfiles\avrb.bat "H:\FLOWCO~1\PROJEC~1\LED Flash.elf" "H:\FLOWCO~1\PROJEC~1\LED Flash.hex" "H:\FLOWCO~1\PROJEC~1\LED Flash.cof"
H:\FLOWCO~1\PROJEC~1>"C:\PROGRA~2\MATRIX~1\FL7431~1\COMPIL~1\avr\BATCHF~1\..\bin\avr-objcopy" -O ihex -R .eeprom "H:\FLOWCO~1\PROJEC~1\LED Flash.elf" "H:\FLOWCO~1\PROJEC~1\LED Flash.hex"
HEX file creation successful!
H:\FLOWCO~1\PROJEC~1>"C:\PROGRA~2\MATRIX~1\FL7431~1\COMPIL~1\avr\BATCHF~1\..\bin\avr-objcopy" -O coff-avr -R .eeprom "H:\FLOWCO~1\PROJEC~1\LED Flash.elf" "H:\FLOWCO~1\PROJEC~1\LED Flash.cof"
COFF file creation successful!
Launching the programmer...
C:\Program Files (x86)\Matrix Multimedia\Flowcode V6\compilers\avr\batchfiles\avrc.bat AVRDUDE m1284p atmega1284p "H:\FLOWCO~1\PROJEC~1\LED Flash.hex" "LED Flash.hex" 0 255 255 255
H:\FLOWCO~1\PROJEC~1>"C:\PROGRA~2\MATRIX~1\FL7431~1\COMPIL~1\avr\BATCHF~1\..\bin\avrdude.exe" -p m1284p -P usb -c avrispmkii -U flash:w:"LED Flash.hex"
avrdude.exe: AVR Part "m1284p" not found.
Valid parts are:
m6450 = ATMEGA6450 [C:\PROGRA~2\MATRIX~1\FL7431~1\COMPIL~1\avr\bin\avrdude.conf:11732]
m3250 = ATMEGA3250 [C:\PROGRA~2\MATRIX~1\FL7431~1\COMPIL~1\avr\bin\avrdude.conf:11543]
m645 = ATMEGA645 [C:\PROGRA~2\MATRIX~1\FL7431~1\COMPIL~1\avr\bin\avrdude.conf:11354]
m325 = ATMEGA325 [C:\PROGRA~2\MATRIX~1\FL7431~1\COMPIL~1\avr\bin\avrdude.conf:11165]
usb1287 = AT90USB1287 [C:\PROGRA~2\MATRIX~1\FL7431~1\COMPIL~1\avr\bin\avrdude.conf:10977]
usb1286 = AT90USB1286 [C:\PROGRA~2\MATRIX~1\FL7431~1\COMPIL~1\avr\bin\avrdude.conf:10788]
usb647 = AT90USB647 [C:\PROGRA~2\MATRIX~1\FL7431~1\COMPIL~1\avr\bin\avrdude.conf:10599]
usb646 = AT90USB646 [C:\PROGRA~2\MATRIX~1\FL7431~1\COMPIL~1\avr\bin\avrdude.conf:10409]
t84 = ATtiny84 [C:\PROGRA~2\MATRIX~1\FL7431~1\COMPIL~1\avr\bin\avrdude.conf:10226]
t44 = ATtiny44 [C:\PROGRA~2\MATRIX~1\FL7431~1\COMPIL~1\avr\bin\avrdude.conf:10044]
t24 = ATtiny24 [C:\PROGRA~2\MATRIX~1\FL7431~1\COMPIL~1\avr\bin\avrdude.conf:9862]
m2561 = ATMEGA2561 [C:\PROGRA~2\MATRIX~1\FL7431~1\COMPIL~1\avr\bin\avrdude.conf:9669]
m2560 = ATMEGA2560 [C:\PROGRA~2\MATRIX~1\FL7431~1\COMPIL~1\avr\bin\avrdude.conf:9476]
m1281 = ATMEGA1281 [C:\PROGRA~2\MATRIX~1\FL7431~1\COMPIL~1\avr\bin\avrdude.conf:9288]
m1280 = ATMEGA1280 [C:\PROGRA~2\MATRIX~1\FL7431~1\COMPIL~1\avr\bin\avrdude.conf:9099]
m640 = ATMEGA640 [C:\PROGRA~2\MATRIX~1\FL7431~1\COMPIL~1\avr\bin\avrdude.conf:8911]
t85 = ATtiny85 [C:\PROGRA~2\MATRIX~1\FL7431~1\COMPIL~1\avr\bin\avrdude.conf:8730]
t45 = ATtiny45 [C:\PROGRA~2\MATRIX~1\FL7431~1\COMPIL~1\avr\bin\avrdude.conf:8551]
t25 = ATtiny25 [C:\PROGRA~2\MATRIX~1\FL7431~1\COMPIL~1\avr\bin\avrdude.conf:8371]
pwm3b = AT90PWM3B [C:\PROGRA~2\MATRIX~1\FL7431~1\COMPIL~1\avr\bin\avrdude.conf:8190]
pwm2b = AT90PWM2B [C:\PROGRA~2\MATRIX~1\FL7431~1\COMPIL~1\avr\bin\avrdude.conf:8007]
pwm3 = AT90PWM3 [C:\PROGRA~2\MATRIX~1\FL7431~1\COMPIL~1\avr\bin\avrdude.conf:7824]
pwm2 = AT90PWM2 [C:\PROGRA~2\MATRIX~1\FL7431~1\COMPIL~1\avr\bin\avrdude.conf:7640]
t2313 = ATtiny2313 [C:\PROGRA~2\MATRIX~1\FL7431~1\COMPIL~1\avr\bin\avrdude.conf:7453]
m328p = ATMEGA328P [C:\PROGRA~2\MATRIX~1\FL7431~1\COMPIL~1\avr\bin\avrdude.conf:7265]
m168 = ATMEGA168 [C:\PROGRA~2\MATRIX~1\FL7431~1\COMPIL~1\avr\bin\avrdude.conf:7077]
m88 = ATMEGA88 [C:\PROGRA~2\MATRIX~1\FL7431~1\COMPIL~1\avr\bin\avrdude.conf:6891]
m48 = ATMEGA48 [C:\PROGRA~2\MATRIX~1\FL7431~1\COMPIL~1\avr\bin\avrdude.conf:6704]
t861 = ATTINY861 [C:\PROGRA~2\MATRIX~1\FL7431~1\COMPIL~1\avr\bin\avrdude.conf:6516]
t461 = ATTINY461 [C:\PROGRA~2\MATRIX~1\FL7431~1\COMPIL~1\avr\bin\avrdude.conf:6327]
t261 = ATTINY261 [C:\PROGRA~2\MATRIX~1\FL7431~1\COMPIL~1\avr\bin\avrdude.conf:6138]
t26 = ATTINY26 [C:\PROGRA~2\MATRIX~1\FL7431~1\COMPIL~1\avr\bin\avrdude.conf:5981]
m8535 = ATMEGA8535 [C:\PROGRA~2\MATRIX~1\FL7431~1\COMPIL~1\avr\bin\avrdude.conf:5823]
m8515 = ATMEGA8515 [C:\PROGRA~2\MATRIX~1\FL7431~1\COMPIL~1\avr\bin\avrdude.conf:5665]
m8 = ATMEGA8 [C:\PROGRA~2\MATRIX~1\FL7431~1\COMPIL~1\avr\bin\avrdude.conf:5505]
m161 = ATMEGA161 [C:\PROGRA~2\MATRIX~1\FL7431~1\COMPIL~1\avr\bin\avrdude.conf:5365]
m32 = ATMEGA32 [C:\PROGRA~2\MATRIX~1\FL7431~1\COMPIL~1\avr\bin\avrdude.conf:5190]
m6490 = ATMEGA6490 [C:\PROGRA~2\MATRIX~1\FL7431~1\COMPIL~1\avr\bin\avrdude.conf:4997]
m649 = ATMEGA649 [C:\PROGRA~2\MATRIX~1\FL7431~1\COMPIL~1\avr\bin\avrdude.conf:4812]
m3290 = ATMEGA3290 [C:\PROGRA~2\MATRIX~1\FL7431~1\COMPIL~1\avr\bin\avrdude.conf:4629]
m329 = ATMEGA329 [C:\PROGRA~2\MATRIX~1\FL7431~1\COMPIL~1\avr\bin\avrdude.conf:4444]
m169 = ATMEGA169 [C:\PROGRA~2\MATRIX~1\FL7431~1\COMPIL~1\avr\bin\avrdude.conf:4264]
m163 = ATMEGA163 [C:\PROGRA~2\MATRIX~1\FL7431~1\COMPIL~1\avr\bin\avrdude.conf:4121]
m162 = ATMEGA162 [C:\PROGRA~2\MATRIX~1\FL7431~1\COMPIL~1\avr\bin\avrdude.conf:3925]
m644p = ATMEGA644P [C:\PROGRA~2\MATRIX~1\FL7431~1\COMPIL~1\avr\bin\avrdude.conf:3734]
m644 = ATMEGA644 [C:\PROGRA~2\MATRIX~1\FL7431~1\COMPIL~1\avr\bin\avrdude.conf:3543]
m324p = ATMEGA324P [C:\PROGRA~2\MATRIX~1\FL7431~1\COMPIL~1\avr\bin\avrdude.conf:3351]
m164p = ATMEGA164P [C:\PROGRA~2\MATRIX~1\FL7431~1\COMPIL~1\avr\bin\avrdude.conf:3159]
m16 = ATMEGA16 [C:\PROGRA~2\MATRIX~1\FL7431~1\COMPIL~1\avr\bin\avrdude.conf:2981]
c128 = AT90CAN128 [C:\PROGRA~2\MATRIX~1\FL7431~1\COMPIL~1\avr\bin\avrdude.conf:2790]
m128 = ATMEGA128 [C:\PROGRA~2\MATRIX~1\FL7431~1\COMPIL~1\avr\bin\avrdude.conf:2612]
m64 = ATMEGA64 [C:\PROGRA~2\MATRIX~1\FL7431~1\COMPIL~1\avr\bin\avrdude.conf:2431]
m103 = ATMEGA103 [C:\PROGRA~2\MATRIX~1\FL7431~1\COMPIL~1\avr\bin\avrdude.conf:2291]
8535 = AT90S8535 [C:\PROGRA~2\MATRIX~1\FL7431~1\COMPIL~1\avr\bin\avrdude.conf:2170]
8515 = AT90S8515 [C:\PROGRA~2\MATRIX~1\FL7431~1\COMPIL~1\avr\bin\avrdude.conf:2056]
4434 = AT90S4434 [C:\PROGRA~2\MATRIX~1\FL7431~1\COMPIL~1\avr\bin\avrdude.conf:1973]
4433 = AT90S4433 [C:\PROGRA~2\MATRIX~1\FL7431~1\COMPIL~1\avr\bin\avrdude.conf:1849]
2343 = AT90S2343 [C:\PROGRA~2\MATRIX~1\FL7431~1\COMPIL~1\avr\bin\avrdude.conf:1725]
2333 = AT90S2333 [C:\PROGRA~2\MATRIX~1\FL7431~1\COMPIL~1\avr\bin\avrdude.conf:1640]
2313 = AT90S2313 [C:\PROGRA~2\MATRIX~1\FL7431~1\COMPIL~1\avr\bin\avrdude.conf:1527]
4414 = AT90S4414 [C:\PROGRA~2\MATRIX~1\FL7431~1\COMPIL~1\avr\bin\avrdude.conf:1414]
1200 = AT90S1200 [C:\PROGRA~2\MATRIX~1\FL7431~1\COMPIL~1\avr\bin\avrdude.conf:1299]
t15 = ATtiny15 [C:\PROGRA~2\MATRIX~1\FL7431~1\COMPIL~1\avr\bin\avrdude.conf:1166]
t13 = ATtiny13 [C:\PROGRA~2\MATRIX~1\FL7431~1\COMPIL~1\avr\bin\avrdude.conf:993]
t12 = ATtiny12 [C:\PROGRA~2\MATRIX~1\FL7431~1\COMPIL~1\avr\bin\avrdude.conf:860]
t11 = ATtiny11 [C:\PROGRA~2\MATRIX~1\FL7431~1\COMPIL~1\avr\bin\avrdude.conf:796]
Error returned from [avrdude]
C:\Program Files (x86)\Matrix Multimedia\Flowcode V6\compilers\avr\batchfiles\avrc.bat reported error code 1
FINISHED
The AVR1284 component file is present and is not corrupted. Tried an earlier FC6 version with the same results.
Simple LED Flasher Test Program
LED Flash.fcfx
(4.05 KiB) Downloaded 265 times
The same program / settings works fine under FC5
Re: AVR 1284p Error
Hi John,
We have recently upgraded to the latest AVRdude software to help better support Arduino devices and this also seems to fix the problem your having.
Extract the contents of the archive into your "Flowcode 6\compilers\avr\bin" directory and hopefully this should resolve the issue.
AVRdude.zip
(531.65 KiB) Downloaded 328 times
JohnCrow
Re: AVR 1284p Error
Post by JohnCrow »
Thanks Benj
Just tried the new files, all works fine now.
