Why is it impossible to load the progam (see attachement) in a 16F88 microcontroller?
I receive the message: "Flash memory not verified - may be due to code protect"
I use a EB 006 00 8 program board in combination with flowcode V6.
Thanks in advance.
Why is it impossible to load that program in a 16F88
- Has thanked: 5 times
- Been thanked: 2 times
- oef80nognietuitgetest.fcfx
- (14.9 KiB) Downloaded 218 times
- JohnCrow
- Has thanked: 364 times
- Been thanked: 716 times
Re: Why is it impossible to load that program in a 16F88
I've just tried your flowchart on my EB006-V9 and EB006-V7 programmers, and it loads into a 16F88 ok.
I don't have a V8 board myself
Are you running the latest version of flowcode (FC 6.0.10) which also will have the latest version of mLoader.
There are a few posts referring to this problem on the forums, might be worth searching for those.
I've attached the hex file from your flowchart, you can try and load it directly with mLoader and hopefully that will get you going for now.
I have sent the hex file with a pickit2 programmer to the chip, and now the programming goes fine.
So I think there is a problem with my EB006 board
- Has thanked: 1135 times
- Been thanked: 299 times
Hi Delak!
I've had the same problem, unstable combiling to chip with different error messages. I downloaded the USB driver and installed it = "EB006 (v8 and older) USB Driver" from:
http://www.matrixtsl.com/search_results ... chText=usb
Whether it directly have anything to do with it, I do not know, but seemed a better results when I combile from FC6 to EB006-8
And one more thing, don´t have anything connected to the port on EB board.
You can give it a try.
Best regard
Jorgen
Best regard
Jorgen
