Clear on 4 digit 7 segment display
Please add any feature requests for Flowcode version 6 here
Forum rules
yutronic
Has thanked: 10 times
Been thanked: 5 times
Post by yutronic »
there is no "clear digit" option on 4 digit 7 segment display which is present in single 7 segment display component. This way display can show ---4 only at the beginning. Afterwards it can only show 0004. I can go around that by using single 7 seg display but maybe it is not to much work to edit the code. Also LATCH switch could also be an option in case someone finds it useful ... :D
Re: Clear on 4 digit 7 segment display
Here is an updated component where I have added value 16 which will act to clear the segment.
led_7seg_quad.fcpx
(24.5 KiB) Downloaded 362 times
Let me know how you get on.
Some of the switches currently have a property allowing them to be momentary or latched. Is there a specific component you had in mind?
