18F252 Internal pull-up
bercioiu
Has thanked: 90 times
Been thanked: 34 times
Post by bercioiu »
I need to activate for the 18F252 internal pull-up and I cant handle...
I put a C code icon with the "intcon2 = 0;" but it activate INT1 at the RB!.
How can I clear only the RBPU (bit7) of the INTCON2 register?
I tried with "clear_bit(intcon2 , 7);" to but the result was the same: All port B is "up", but RB1 is low...
18F252.pdf
(3.14 MiB) Downloaded 300 times
Re: 18F252 Internal pull-up
To enable the weak pull up on that pin you need to clear bit 7 of intcon2 and also set the bit of the tris register to convert the pin into an input.
set_bit(trisb, 1);
bercioiu
Post by bercioiu »
I need to enable weak pull up for all bytes of the port B, thank you!
Ok this code should work.
trisb = 0xFF;
bercioiu
Post by bercioiu »
The same situation... RB1 is low :-(
This is the schematic:
(68.79 KiB) Downloaded 979 times
