Addition for a BLDC Motor(PMSM Machine )
Please add any feature requests for Flowcode version 6 here
Forum rules
QMESAR
Has thanked: 384 times
Been thanked: 614 times
Post by QMESAR »
Hi Team
I would like to ask if you would consider the addition of a Permanent Magnet Motor component. or PMSM machine
this would be very kind as many industrial application today are moving towards PMSM motors .
As a firsts only the motor with it 3 phase windings would help as we could do the control for the B6 bridge in a C file however if you would include the
control algorithms it would be great :D
Peter
Re: Addition for a BLDC Motor(PMSM Machine )
Hi Peter,
Thanks for your suggestion.
I've added it to the list of potentials so we can have a look and see how easy it would be to achieve.
QMESAR
Post by QMESAR »
Hi Benj
just as an information Microchip has many application notes which shows the implementation of BLDC Motor Control such as Sensor less and FOC and then the basic Block commutation which is actually only and array with 6 elements
and the generation of 3 complimentary PWM signals
Peter
I will try on this weekend to run my existing block commutation Code in a FC6 flow diagram probably with assistance I could make an component of this which all of us could use just a thought :D
