AutoVersionID bug
soos-dezso
Has thanked: 3 times
Been thanked: 2 times
AutoVersionID bug
Post by soos-dezso »
Hi.
I find one bug. The date is incorrect in this component.
How to correct this ?
Thank You.
Re: AutoVersionID bug
Many thanks for the bug spot. I have found the source of the issue and fixed it in the component.
AutoVersionID.fcpx
(2.16 KiB) Downloaded 279 times
If you copy the file here "C:\Program Files (x86)\Flowcode 6\components" and then restart Flowcode the problem should resolve itself next time you compile.
Thought while I was in the component I would also add a US date format option. Seems to be working correctly if anyone needs this functionality.
AutoVersionID.fcpx
(2.28 KiB) Downloaded 294 times
soos-dezso
Thank You!
But possible to make YY MM DD setting in DateFormat selection menu?
Dezso
Yes this is possible, now added as an option.
AutoVersionID.fcpx
(2.41 KiB) Downloaded 270 times
