DS3231 on FCV5
bercioiu
Has thanked: 90 times
Been thanked: 34 times
DS3231 on FCV5
Post by bercioiu »
I`m working on a wristwatch. The HV it`s almost ready. In the mean time, I want to work at the software, but encountered a problem, I cant handle with DS3231. I thought it is the same as in 1307 but it does not work at all...
There is anybody on that forum to help me with an example with DS3231 for Flowcode V5?
Thank you in advance!
Puiu,
Dan81
Been thanked: 60 times
Re: DS3231 on FCV5
Post by Dan81 »
Did you connect all the pins (5 to 13) to ground ?
Daniel
bercioiu
Re: DS3231 on FCV5
Post by bercioiu »
Yep, mean time I manage to communicate with it... But still need help to use all feature of the chip (temp, alarm, etc.).
Also, I need help to display on 7segment some custom characters.
Thank you!
Puiu,
bercioiu
Re: DS3231 on FCV5
Post by bercioiu »
Just out of curiosity: For version 5 of Flowcode is still providing support?
Thank you!
Re: DS3231 on FCV5
Sorry for the delay yes v5 is still under support.
Let us know if you get stuck with the alarm and temp functionality. Also if you post what you have so far or even better a simplified version of what you need to get working then we can try and dig in and help.
Custom characters on the 7-seg can be achieved by writing values directly to the port to correspond to the LEDs on the display you want to light.
bercioiu
Re: DS3231 on FCV5
Post by bercioiu »
I already solved, thanks for the support.
Has thanked: 1135 times
Been thanked: 299 times
Re: DS3231 on FCV5
Post by jgu1 »
Hi Bericou!
Is it a project you will share, I'm curious. :)
Best regard
Jorgen
bercioiu
Re: DS3231 on FCV5
Post by bercioiu »
When will be ready, i`ll post all files. It is an wrist clock with 7 segment leds.
For the moment, I have some trouble with the charger on board for the Li-Po accu...
(476.33 KiB) Downloaded 1883 times
Re: DS3231 on FCV5
Post by jgu1 »
Hi!
Wery Nice project. Thank's. Look forward to see the code.
Jorgen
