Rename macro local vars does not update references
kersing
Has thanked: 553 times
Been thanked: 1081 times
Post by kersing »
When renaming local variables/parameters in a macro the references in the macro itself are not updated to reflect the new name. As renaming global variables renames all occurrences it would be nice if this worked for local variables/parameters as well.
― C.S. Lewis
Re: Rename macro local vars does not update references
Hi Jac,
How are you renaming the variables. I believe it works via the project explorer interface but if you are using another method then there could be a bug.
kersing
Post by kersing »
Hi Ben,
Renaming by opening the macro with 'Macro->Edit Details...', edit the parameter/local variable by choosing 'edit' from the drop down menu (arrow next to the name), enter a new name and save with 'OK', next use 'OK' to close the 'Edit Macro Details' dialog.
― C.S. Lewis
Thanks Jac, It's now on the to do list.
