Confused with EB093
MJU
Has thanked: 121 times
Been thanked: 108 times
Confused with EB093
Post by MJU »
I have got the EB093 Arduino compatible E-block shield, with the EB093 Combo board.
But, I want to use instead of the combo board other Eblocks.
On the combo board the ports are marked with the same signs as used in Flowcode (Port A/B).
This is easy.
But now I want to connect the push button board EB007, so I have to look which port in Flowcode I need to assign to it.
In Flowcode I think I need port A0-A6 and connect these to the Arduino hardware pins marked: C0-C5 (on the EB093).
On the port marked D0-D7 on the Arduino board, I want to connect the LCD board: EB005.
In Flowcode this becomes: pin B0-B07
If I want to connect something to D8-D13 on the EB093, this will become port C?
I'm confused..
I've made a screenshot of how I think it should be.
Is this right?
There is no datasheet with a schematic for this EB093 so I'm not sure.
Maybe, if this is right, could it be used in the datasheets for the E-blocks?
Re: Confused with EB093
If you look at the chip window then it will show you the port mapping to the Arduino style A and D pins. The mapping can be a bit all over the place so it depends on which Arduino your using.
MJU
Post by MJU »
Benj wrote:Hello,
Thank you BenJ,
Now I see the reference in the chip window.
My mistake.
Is it possible to emphasise these some what more in later versions of FC?
Thank you!
