Erorr I2C
Support-Forum für Deutschsprachige, die in ihrer Muttersprache schreiben möchten.
PHolz
Erorr I2C
Post by PHolz »
Hallo,
ich habe mit Flowcode 6 ein Problem mit der I2C Masterfunktion.
Sobald ich die Hardware Bussettings auf "Channel1" stelle, erhalte ich beim kompilieren viele Fehlermeldungen:
http://www.flowcode.co.uk
Start des Compilers...
C:\Program Files (x86)\Flowcode 6\compilers\pic\boostc\boostc_16F.exe -v -t PIC16F877A "I2C EEPROM read and write.c"
Launching BoostC...
BoostC Optimizing C Compiler Version 7.20 (for PIC16 architecture)
http://www.sourceboost.com
Copyright(C) 2004-2013 Pavel Baranov
Copyright(C) 2004-2013 David Hobday
Licensed to FlowCode User under Single user Pro License for 1 node(s)
Limitations: PIC12,PIC16 max code size:Unlimited, max RAM banks:Unlimited
Starting preprocessor: "C:\Program Files (x86)\Flowcode 6\compilers\pic\boostc\pp.exe" "I2C EEPROM read and write.c" -i "C:\Program Files (x86)\Flowcode 6\compilers\pic\boostc\include" -d _PIC16F877A -la -c2 -o "I2C EEPROM read and write.pp" -v -d _BOOSTC -d _PIC16 -d _CHAR_INDEX
C:\Program Files (x86)\Flowcode 6\CAL\PIC\PIC_CAL_I2C.c(466:2): error: unknown identifier 'sspcon1'
C:\Program Files (x86)\Flowcode 6\CAL\PIC\PIC_CAL_I2C.c(466:2): error: invalid operand 'sspcon1'
C:\Program Files (x86)\Flowcode 6\CAL\PIC\PIC_CAL_I2C.c(466:10): error: failed to generate expression
C:\Program Files (x86)\Flowcode 6\CAL\PIC\PIC_CAL_I2C.c(468:2): error: unknown identifier 'sspcon3'
C:\Program Files (x86)\Flowcode 6\CAL\PIC\PIC_CAL_I2C.c(468:2): error: invalid operand 'sspcon3'
C:\Program Files (x86)\Flowcode 6\CAL\PIC\PIC_CAL_I2C.c(468:10): error: failed to generate expression
C:\Program Files (x86)\Flowcode 6\CAL\PIC\PIC_CAL_I2C.c(469:2): error: unknown identifier 'sspmsk'
C:\Program Files (x86)\Flowcode 6\CAL\PIC\PIC_CAL_I2C.c(469:2): error: invalid operand 'sspmsk'
C:\Program Files (x86)\Flowcode 6\CAL\PIC\PIC_CAL_I2C.c(469:9): error: failed to generate expression
C:\Program Files (x86)\Flowcode 6\CAL\PIC\PIC_CAL_I2C.c(503:4): error: unknown identifier 'sspcon1'
C:\Program Files (x86)\Flowcode 6\CAL\PIC\PIC_CAL_I2C.c(503:4): error: failed to generate expression
C:\Program Files (x86)\Flowcode 6\CAL\PIC\PIC_CAL_I2C.c(503:4): error: invalid operand 'sspcon1'
C:\Program Files (x86)\Flowcode 6\CAL\PIC\PIC_CAL_I2C.c(503:13): error: failed to generate expression
C:\Program Files (x86)\Flowcode 6\CAL\PIC\PIC_CAL_I2C.c(517:4): error: unknown identifier 'sspcon1'
C:\Program Files (x86)\Flowcode 6\CAL\PIC\PIC_CAL_I2C.c(517:4): error: failed to generate expression
C:\Program Files (x86)\Flowcode 6\CAL\PIC\PIC_CAL_I2C.c(517:4): error: invalid operand 'sspcon1'
C:\Program Files (x86)\Flowcode 6\CAL\PIC\PIC_CAL_I2C.c(517:13): error: failed to generate expression
C:\Program Files (x86)\Flowcode 6\CAL\PIC\PIC_CAL_I2C.c(540:27): error: unknown identifier 'R_NOT_W'
C:\Program Files (x86)\Flowcode 6\CAL\PIC\PIC_CAL_I2C.c(540:27): error: failed to generate expression
C:\Program Files (x86)\Flowcode 6\CAL\PIC\PIC_CAL_I2C.c(540:27): error: invalid operand 'R_NOT_W'
C:\Program Files (x86)\Flowcode 6\CAL\PIC\PIC_CAL_I2C.c(540:22): error: failed to generate expression
C:\Program Files (x86)\Flowcode 6\CAL\PIC\PIC_CAL_I2C.c(540:20): error: invalid operand '1 << ( R_NOT_W)'
C:\Program Files (x86)\Flowcode 6\CAL\PIC\PIC_CAL_I2C.c(540:17): error: failed to generate expression
I2C EEPROM read and write.c success
failure
Completed BoostC compilation, return = 1
C:\Program Files (x86)\Flowcode 6\compilers\pic\boostc\boostc_16F.exe Hat den Fehlercode 1 gemeldet
BEENDET
Bei der Einstellung Software funktioniert das Programm. Auch wenn ich das Programm unter FCV5 kompiliere funktioniert es. (auch für Channel1)
Das Programm "I2C EEPROM read and write.fcfx" habe ich aus den Beispielen geladen.
Wer kann mir sagen wo das Problem liegt?
QMESAR
Has thanked: 384 times
Been thanked: 614 times
Re: Erorr I2C
Post by QMESAR »
Hallo
Der I2C-Komponentendefinition in Flowcode ist nicht korrekt, ich habe den gleichen Fehler beim Kompilieren .
Gruss
I believe there is an error with the I2C master component on this device as I have the same problem when compiling for an 877A
Re: Erorr I2C
Hallo,
Vielen Dank, dass Sie uns wissen . Die angehängte Datei sollte das Problem lösen . Bitte kopieren Sie sie in Ihren "C:\Program Files (x86)\Flowcode 6\CAL\PIC" Ordner und neu kompilieren .
PIC_CAL_I2C.c
(20.66 KiB) Downloaded 792 times
Thanks for letting us know. The attached file should solve the problem. Please copy it into your "C:\Program Files (x86)\Flowcode 6\CAL\PIC" folder and re-compile.
PIC_CAL_I2C.c
