Editing code component like in FC V4 ?
milea
Flowcode V4 User
Post by milea »
I'm migrating from v4 to v6.
In v4 I can edit/change the code (custom) of the component. It is easy and simple, in Panel right click on the component->custom code. After that if everything is OK, I were changed the component c code in \Flowcode V4\components directory for permanent usage.
My question is:
1.where can I see the code for each component?
2.Pls tell me the way of change it.
Kind regards
kersing
Has thanked: 553 times
Been thanked: 1081 times
Re: Editing code component like in FC V4 ?
Post by kersing »
Due to the different way components are constructed in FC6 the source is not available and can not be changed. If you require a specific change you could ask Matrix to include it in the component or create an customized component for you.
― C.S. Lewis
