192x63 KS0108 Problem
Emanuel Lourenco
Been thanked: 8 times
Post by Emanuel Lourenco »
I bought this lcd
http://www.ebay.co.uk/itm/192x64-Graphi ... 43c14da9fd
But the pixels 124-192 do not work.
Know what can be?
And how to solve?
Best Regards
Re: 192x63 KS0108 Problem
Can you attach your current program so we can see what your currently doing.
Emanuel Lourenco
hi
Yes I apologize
I leave my program
I leave the pins lcd I'm connect
I leave the result that gives me in practice
Best Regards
Result
(1.19 MiB) Downloaded 518 times
Pins
(15.82 KiB) Downloaded 1970 times
Centralina_Solar_V1.1_LCD.fcfx
Program
(6.66 KiB) Downloaded 252 times
Thanks for the info that helps. I have looked at the component code and it seems to be ok but I don't have a 3 controller display here to test. I did think that I put in the 3rd controller upon request though so thought a customer had it working?
So it could be that the code has a problem or it could be that something is up with your display or the connections to the display.
Out of interest what happens if you change the DrawLine macro call coords from 0, 40, 192, 40 to 0, 40, 191, 40?
Also in your configuration settings the "Watchdog Timer Enable Bit" is enabled, what happens if you disable this?
Emanuel Lourenco
hello Benj
The problem is solved.
The CS3 was connected to the G9 pin and did not work, I moved to another pin and longer works. Not what was the reason for it does not work.
Thanks for the help
Best Regards
