Model for the EB008 7 Segment E Block
A forum where Flowcode v6 user created components can be shared, discussed and reviewed.
QMESAR
Has thanked: 384 times
Been thanked: 614 times
Post by QMESAR »
As I am working with a design using the EB008 I made a model for it in Proteus which you guys using Proteus can use for simulation
I include a hex file that runs the number 6513 on the display .
Obviously you can run your FC generated hex file and it will show your code
hope it helps some one :D
MATRIX EB008 Model.zip
(33.58 KiB) Downloaded 394 times
(141.11 KiB) Downloaded 1042 times
