I reviewed the assembly output for one of my PIC projects using FC 6.1.1.0, specifically the code generated for a custom interrupt, and noticed that the GIE flag gets set before the interrupt is setup. This means that the code setting or intializing the interrupt runs after the global interrupt flag is set i.e. after all interrupts are enabled. This may cause some initial, sporadic and unexpected behaviour. Should this not be placed instead just at the end of setting up the interrupt right after the PIE is enabled for example?
I also checked similar code for some of the predefined interrupt sources, such as timer 0, and found that the GIE is handled as expected, so ti apperas that just the customs interrupt code is affected.
Is it possible to make a note of this and correct in future releases?
Custom interrupts enable GIE too early
Re: Custom interrupts enable GIE too early
The custom interrupt code can be altered by you if you would like to change the order. Are you saying that the demo examples in the Wiki have the incorrect order?
I don't think there will be any massive problems that come from enabling the GIE first unless there are other interrupt flags that have been enabled elsewhere in your program.
- QMESAR
- Has thanked: 384 times
- Been thanked: 614 times
I agree with this 100%Benj wrote:Hello,
Regards QMESAR
Regards QMESAR
Nothing massive just odd.
As a work around the first thing I do is clear the GIE flag then setup the interrupts and at the end re-enable GIE.
The code I was referring to is generated when one selects any of the predefined interrupt sources associated with the INT symbol. Drag the INT into your flowchart, double click on it, check the Enable interrupt radio button and the select the interrupt source from the drop down list Interrupt on. In this code the GIE is set right at the end after setting PIE.
