DSP output to a real PIC pin??
Dirk Bubley
Has thanked: 14 times
Been thanked: 12 times
Post by Dirk Bubley »
Hello together,
Hello Matrix Team,
I´m trying to learn more aboud the DSP components and the related functions.
I started with the fequency Generator example and modified it.
In Simulation I see the result of my chances and manipulation. (Console window)
Question!! How can I map the results/calculations let´s say of DSP pulse Generator System to a real output pin of a PIC chip?
BR
Dirk
Re: DSP output to a real PIC pin??
Hi Dirk,
Here I modified the signal generator example slightly by adding an output DSP component and using this to collect the value from the DSP chain and pass to a PWM component. By using a capacitor and a resistor you can create a simple low pass filter to filter out the high frequency PWM and create a simple DAC.
FreqGen.fcfx
(10.88 KiB) Downloaded 381 times
Dirk Bubley
Hi Ben,
many thanks for the support. After a short look it is more clear to me. now
I will check it out next weekend with the real pic chip.
BR
Dirk
organetic
Has thanked: 1 time
Post by organetic »
Dear Benj,
Would you be so kind and let me know how to redirect the output from the frequency generator directly to a port?
My idea is to use these pulses to control stepper motors with pulse/dir drivers.
Also, what is the maximum frequency that this generator is capable to reach using arduinos?
Cheers!
Nuno
You might be better off not using the DSP components to drive stepper motors. If you are using a stepper driver board that only requires direction and step signals then I would simply use two LED components to drive your outputs.
Using a timer interrupt you can establish a fixed speed to toggle your step signal and move the motor.
