I'm trying to show a picture of 32x32 in a glcd with KS0108 using one of the processes already described in another post using call C instead of using a buffer type "\ xFF \ x00 \ x80 ....." .
It turns out that yes I can show the whole picture in cordenada "X" desired but the same does not happen in cordenada "Y" even if you set 0 to "Y " image always begins starting at 32 .
using the real component or simulation with " Proteus " has the same behavior .
aid would be welcome ....
Thanks in advance !
http://www.flowcode.co.uk/mmforums/viewt ... map#p37351
