Microchip not on the Flowcode list
- Jan Lichtenbelt
- Has thanked: 128 times
- Been thanked: 264 times
I intended to use the 16F1788 microchip (and bought it already). But now I find out that is not on the flowcode list. What to do?
With kind regards
Jan Lichtenbelt
With kind regards
Jan Lichtenbelt
kersing
- Has thanked: 553 times
- Been thanked: 1081 times
Re: Microchip not on the Flowcode list
Jan,
As BoostC does not support this device Flowcode can not support it. Someone needs to create the files for The C compiler to support it, next Flowcode definitions can be created. I've done it in the past, as have others on the forum, and only had issues once due to a compiler bug that required fixing.
Best regards,
Jac
Best regards,
Jac
― C.S. Lewis
― C.S. Lewis
This chip family including the 16F1788 device have now been added and will be in the next update release which is due to be released soon.
They have not been tested by us but should function ok.
The files are also available on the forums if you want to get access to these chips before the update is released.
- Jan Lichtenbelt
Hi Benj,
I'm intrested in the files, but can not find them. Can you give the link?
Kind regards
Jan Lichtenbelt
Kind regards
Jan Lichtenbelt
- Jan Lichtenbelt
Hi Martin
I did download the 16F1788.fcdx. I started Flowcode 6 again, but did not see the microchip in the list. Do I need also the 16F1788.h and/or .bas files?
With kind regrads
Jan Lichtenbelt
With kind regrads
Jan Lichtenbelt
I would have thought you require all the relevent files including map.txt within PIC16(L)F178x.rar posted a couple of posts above?
- Jan Lichtenbelt
The zip file contains only the .fcdx files. All other files are for 16F1784 but not the 16F1788 (which I want to use)
Kind regrads
Jan
Kind regrads
Jan
Hi Jan,
A screen shot shows: Martin
The file i'm refering to a couple of posts up is this postmedelec35 wrote:I would have thought you require all the relevent files including map.txt within PIC16(L)F178x.rar posted a couple of posts above?
Hi Jan,
I have just sent you a PM regarding 16F1788
