Message compilateur
Philbert Pascal
Been thanked: 4 times
Message compilateur
Post by Philbert Pascal »
Benj Hello,
my ongoing worries. I have a message at compile time:
" Software return call stack table Exceeds maxium length of 256 entries in function 'FCM_PositionTempo' "
I had to exceed the limit of my peak, but what should I do in my code?
Thank you in advance for your help.
Pascal
Bonjour Benj,
mes soucis continues. j'ai un message au moment de la compilation:
Software call stack return table exceeds maxium length of 256 entries in function:'FCM_PositionTempo'
J'ai dû dépasser la limite de mon pic, mais que dois je faire dans mon code?
Merci d'avance pour ton aide.
Pascal
Code_Escalier_PIC18F4680_V5.1.4.xMarches_Wifi_pour_gravure.fcfx
(832.87 KiB) Downloaded 583 times
Re: Message compilateur
Hello Pascal,
You can try disabling the BoostC software call stack by using the compiler options window.
Build -> Compiler options -> Linker / Assembler Tab
In the Parameters text field try removing this from the very end.
-swcs 6 2
This should then resort to the hardware call stack which should hopefully solve the problem for you.
Let me know how you get on.
Philbert Pascal
Benj Hello,
I remove -swcs 6 2 ", but it generates a new problem.
Already it can not find my programmer. Here is the message.
And error messages still exist.
Clean: Deleting intermediary and output files.
Clean: Deleted file "Test_18F4680.err".
Clean: Deleted file "T:\Développement Escalier\MPLAB_Microchip\Test_18F4680.cod".
Clean: Deleted file "T:\Développement Escalier\MPLAB_Microchip\Test_18F4680.hex".
Clean: Deleted file "Test_18F4680.lst".
Clean: Done.
Executing: "C:\Program Files (x86)\Microchip\MPASM Suite\MPAsmWin.exe" /q /p18F4680 "Test_18F4680.asm" /l"Test_18F4680.lst" /e"Test_18F4680.err"
Warning[220] T:\DéVELOPPEMENT ESCALIER\MPLAB_MICROCHIP\TEST_18F4680.ASM 31696 : Address exceeds maximum range for this processor.
Warning[220] T:\DéVELOPPEMENT ESCALIER\MPLAB_MICROCHIP\TEST_18F4680.ASM 31697 : Address exceeds maximum range for this processor.
Warning[220] T:\DéVELOPPEMENT ESCALIER\MPLAB_MICROCHIP\TEST_18F4680.ASM 31698 : Address exceeds maximum range for this processor.
Warning[220] T:\DéVELOPPEMENT ESCALIER\MPLAB_MICROCHIP\TEST_18F4680.ASM 31699 : Address exceeds maximum range for this processor.
Warning[220] T:\DéVELOPPEMENT ESCALIER\MPLAB_MICROCHIP\TEST_18F4680.ASM 31700 : Address exceeds maximum range for this processor.
Warning[220] T:\DéVELOPPEMENT ESCALIER\MPLAB_MICROCHIP\TEST_18F4680.ASM 31701 : Address exceeds maximum range for this processor.
Warning[220] T:\DéVELOPPEMENT ESCALIER\MPLAB_MICROCHIP\TEST_18F4680.ASM 31702 : Address exceeds maximum range for this processor.
Loaded T:\Développement Escalier\MPLAB_Microchip\Test_18F4680.cod.
BUILD SUCCEEDED: Wed May 13 19:14:46 2015
Pending read you
I really need to deliver an Urgent my client.
PS You can take control of my computer with the TeamViewer software.
cordially
pascal
(133.68 KiB) Downloaded 3770 times
Philbert Pascal
Bonjour Benj,
as-tu eu des nouvelles pour mon problème de compilation?
Je suis complétement bloqué.
Merci d'avance
Pascal
