Remote Control 1 Fan & 2 light with 7 Segregate Display
I need a flowcode which i can operate a remote control 1 Fan & 2 light with 7 Segregate Display. Any Expert Brother would like to help me Plz.
Re: Remote Control 1 Fan & 2 light with 7 Segregate Display
From memory the EB060 E-block is our IR board and compatible with the Flowcode RC5 component. There should be a Flowcode example and a schematic you can follow if you go to the product page.
The EB008 likewise is our 7-seg E-block and again should help to light the way on how to drive it.
Driving larger loads such as a Fan will likely require something like a NPN transistor, a base resistor and a protection diode.
Have a go and then if you run into problems post your file so far and we can try to help you out.
