DS18S20 in high resolution mode (16 Bit)
Support-Forum für Deutschsprachige, die in ihrer Muttersprache schreiben möchten.
kaufparkangucker
Post by kaufparkangucker »
Hi Forum Community,
I use Flowcode 5 since some years for small, simple projects. I use a lot of DS18S20 - temperature sensors in some Projects. For a new project I need the high 16 Bit resolution of the DS18S20.
I try the example made from Benj in post number 13: http://www.matrixtsl.com/mmforums/viewt ... bit#p26668
I attached this flowchart to this posting.
It works, but it works not good.
In high resolution mode, the DS18S20 should produce a multible of 0.0625:
x.0625
x.125
x.1875
x.25
x.3125
x.375
x.4375
x.5
x.5625
x.625
x.6875
x.75
x.8125
x.875
x.9375
(x+1).0
What I get, when I warm up the sensor very slowly:
31.000000
31.062500
31.125000
31.187500
31.250000
31.312500
31.375000
31.437500
Jump to 32.000000
32.000000
32.062500
32.125000
32.187500
32.250000
32.312500
32.375000
32.437500
Jump to 33.000000
The Jump need a lot of time, cause i warm up the sensor realy realy slowly. It is enough time to show the correct values between x.437500 and jump to next higher degree (x+1).000000 but it is not.
I do not finde the problem in benj's code, maybe someone can help me.
best Kauf
DS18S20 Test v1 (Benj).fcf
Benj's DS18S20
(15 KiB) Downloaded 915 times
