gLCD EBM001 in mode SPI
cubitus54
Flowcode v5 User
Has thanked: 7 times
Been thanked: 32 times
Post by cubitus54 »
Is it possible to change the type of screen EBM001 SPI hardware?
On the version of Flowcode V5 FC5_xxx_gLCD_.c in the SPI output software.
On the V6 version of Flowcode, the function is compressed and unchangeable ...
Thank you
V5 FC5_xxx_gLCD_.c
void gLCD_SendByte (char Command, unsigned int Lcdout)
/*Macro_gLCD_SendByte_Start*/
	char i, data;
	//unsigned int mask = 0x8000;
	FC_CAL_Bit_Low (%a_MX_GFXLCD_PORT_CS, %a_MX_GFXLCD_PIN_CS);				//MX_GFXLCD_CS 0 start of sequence
	if (Command == MX_GFXLCD_CMD)
		FC_CAL_Bit_Low (%a_MX_GFXLCD_PORT_RS, %a_MX_GFXLCD_PIN_RS);			//0 = MX_GFXLCD_CMD
	else
		FC_CAL_Bit_High (%a_MX_GFXLCD_PORT_RS, %a_MX_GFXLCD_PIN_RS);		//1 = MX_GFXLCD_PARAMeter
	data = Lcdout;
	for (i=0;i<8;i++)
		FC_CAL_Bit_Low (%a_MX_GFXLCD_PORT_CL, %a_MX_GFXLCD_PIN_CL);			//Clock 0
		if (data & 0x80)
			FC_CAL_Bit_High (%a_MX_GFXLCD_PORT_SD, %a_MX_GFXLCD_PIN_SD);    //Output MSB
		else
			FC_CAL_Bit_Low (%a_MX_GFXLCD_PORT_SD, %a_MX_GFXLCD_PIN_SD);
		FC_CAL_Bit_High (%a_MX_GFXLCD_PORT_CL, %a_MX_GFXLCD_PIN_CL);		//Clock 1
		data = data << 1;                       							//Shift Data to left
	FC_CAL_Bit_High (%a_MX_GFXLCD_PORT_CS, %a_MX_GFXLCD_PIN_CS);			//End of sequence
/*Macro_gLCD_SendByte_End*/
Flowcode V6.1.2.0(11 05 2015)
Re: gLCD EBM001 in mode SPI
Hello Cubitus,
Here is the component source for the EBM001 in FC6.
glcd_EBM001.fcfx
(80.45 KiB) Downloaded 428 times
Let me know how your getting on.
cubitus54
Flowcode v5 User
Post by cubitus54 »
Thank you very much ;)
cubitus54
Flowcode v5 User
Post by cubitus54 »
Is it possible to create an integrated component in Flowcode?
glcd_EBM001_spi.fcfx
(82.81 KiB) Downloaded 499 times
Timing
SPI Hardware : 0,5µs/div
Yes you simply use the file -> Export menu and then move the created file into your Flowcode 6/components directory.
Do you want the new component including in the official build?
cubitus54
Flowcode v5 User
Post by cubitus54 »
Excellent ! :D :D
Why not :)
I may be a few other programs propose to you...
cubitus54
Flowcode v5 User
Post by cubitus54 »
I'd like to try to transform EBM016_Humidity.fcpx in DHT11, DHT22.
Can you give me the component source
Thank you
Ok I will add your modified component to the build. Can you tell me if there is a specific driver IC or display that works with your modified component so I can add the correct info to the tooltip help.
Here is the EBM016 component source.
EBM016v1.fcfx
(28.18 KiB) Downloaded 413 times
cubitus54
Flowcode v5 User
Post by cubitus54 »
Thank you for the humidity sensor.
The display is 1.8 or SPI. there is not really a reference and there are many version for this inexpensive and popular display.
aff_1.8 spi.jpg (122.08 KiB) Viewed 8837 times
cubitus54
Flowcode v5 User
Post by cubitus54 »
More faster :)
Clear all screen in 215 ms -> 160 ms
if one uses an element in the SPI bus.
You can put the CS line to 0 and 0 to let it saves time and makes the fastest display.
cubitus54
Flowcode v5 User
Post by cubitus54 »
More more faster :):)
Only for Ardiuno Mega
I use er SPI register directly (SPDR) in a command C..
90ms for clear all screen :D :D
