Some troubles with RF module
Mathy
Has thanked: 30 times
Been thanked: 33 times
Post by Mathy »
I tried to send data over RF link by the same module used in the EB063 block.
I made simple program with Flowcode 6 who blink a LED to see what is working or not.
The led blink but I lose lots of data....when it is working !
I tried in the past those same module but with Flowcode 5 without any problem.
So I made the same program with Flowcode 5.........and it's work very well !!
Then I import this Flowcode 5 program in Flowcode 6. I had to replace some macro because Flowcode won't compile but the result is the same flowchart and....it is not working...
Is it possible to have a look ?
kersing
Has thanked: 553 times
Been thanked: 1081 times
Re: Some troubles with RF module
Post by kersing »
Could you please post your not working flowchart?
― C.S. Lewis
Mathy
Post by Mathy »
You can see in the attached files, the flowchart made with Flowcode 5 who is working great
FC5_RX.fcf
(13 KiB) Downloaded 457 times
FC5_TX.fcf
(9 KiB) Downloaded 432 times
Mathy
Post by Mathy »
And here, you can see in the attached file the same flowchart made with Flowcode 6 who does not work on the same hardware.
FC5_TX works with FC5_RX
FC5_TX works with FC6_RX
FC6_TX doestn't work with FC5_RX
FC6_TX doesn't work with FC6_RX
So, I think there is something wrong with the FC6_TX file but what ?
Thank you for your help :)
FC6_RX.fcfx
(10.27 KiB) Downloaded 405 times
FC6_TX.fcfx
(8.19 KiB) Downloaded 361 times
Mathy
Post by Mathy »
I tried one other thing.
I used the sendbyte and the reveive byte macro but with the exact same result.
I think there is really a problem with the RF component on Flowcode V6.1.2.0
What can I do to test to help you to find what is going wrong ?
Thanks for the files they should help us to get to the bottom of the issue.
I may have found a small bug in the v6 component so here is a slightly modified version of the component. Let me know how your getting on and I will continue investigating the problem.
RF_ISM.fcpx
(17.55 KiB) Downloaded 419 times
Mathy
Post by Mathy »
Hello Benj,
I tested with the file I attached in my previous post but I have no change.
With FC6_TX, the LED doesn't blink
With FC5_TX, the LED blink
Ok thanks I will continue my investigation.
