PWM Simulation
Bachman
Has thanked: 9 times
Been thanked: 53 times
PWM Simulation
Post by Bachman »
Hello!
PWM -> Properties -> Simulation -> Displayed Periods
Doesn't matter if it's 1, 2 or 3, the result always 1.
Re: PWM Simulation
Thanks for letting us know. I have removed the property for now.
Please let me know if you think multiple periods is a good feature. If you think it is worth having then I will bring it back and make sure it functions correctly.
Bachman
Re: PWM Simulation
Post by Bachman »
Hello!
I think, one period is enough.
Bachman
Re: PWM Simulation
Post by Bachman »
Hello!
I've dowloaded the new files from here: Flowcode 6 - latest components, bug fixes and improvements (Last update: 03/12/15). With the new files, the PWM component "Diplayed Periods" option gone, but two other bugs come out. With 100 % duty cycle, the blue line does't show. The biggest problem is, the PWM output on the HW always low, the pwm is not working (or always 0 % duty cycle). Test program is attached. I've compiled the program with the new files and with the old ones. As you can see, the checksum of the two result is different.
After found this, i've completly restored the "Flowcode 6" folder from a backup.
PWM_test.fcfx
(3.69 KiB) Downloaded 340 times
Bachman
Re: PWM Simulation
Post by Bachman »
The previous post born because of the original PWM component contain a big bug and i tried to solve it with the newest component. Setting the duty cycle to 255, does not set in the HW to 100 %, while in the simulation looks good. Used the test program from the previous post (1 sec 100 %, 1 sec 0 % Duty Cycle).
Tested on:
12F615
16F628A
18F1320
18F14K22
18F26K22
Tested with oscilloscope and a Logic Analayser, same results:
Re: PWM Simulation
Out of interest if you drop the "Period Overflow" property from 255 to 254 does this solve the problem?
We simply set the chip registers and leave it to get on with it so could be a limitation of the hardware?
