2 "IDENTICAL" SIMPLE PROGS, 1 WORKS, 1 DOESN'T
E*2Engineer
Has thanked: 12 times
Been thanked: 6 times
Post by E*2Engineer »
Who can tell me which one won't run after being programmed, and why, because this FC 6 rookie is LOST.
I really do need to know this, as I am completely stuck, and need to get a project done.
I have had this problem in the past, where an older version of a program works, (in V4.5) but a re-written "identical"
one does not run! AHHHHHHHHHHHH
Please Help.
Craig
PORT A TEST ALTERNATE.fcfx
IT'S A PORT A FLASHER, WORK OR NOT?
AND WHY!
(4.38 KiB) Downloaded 225 times
LED FLASHER.fcfx
AND WHY!
(4.69 KiB) Downloaded 256 times
dazz
Has thanked: 474 times
Been thanked: 458 times
Re: 2 "IDENTICAL" SIMPLE PROGS, 1 WORKS, 1 DOESN'T
Post by dazz »
both should work however the configs are different, i always switch pwr up timer on and low voltage program off, im sure your aware that one progran will switch on all led's the other will flash selected ones.
i havent got time to check in hardware(need to replace hydraulic cylinders on car). so sort out the configs and try again
forgot to say for something that simple it isn't worth using external xtal, use the internal one
let us know if it works
Dazz
