ADC Vref hardware setting
jadiflow
Flowcode v5 User
Has thanked: 19 times
Been thanked: 16 times
Post by jadiflow »
I searched the forums and though several users had this issue I didn't see a solution for this.
I want to use the Vref input pin for the ADC reference (16PIC886).
I set the Component properties for the ADC to +Vref.
I assume I also need to set up the appropriate input ports, so right after the macro call to RAW_configure the ADC I place an asm block:
asm
bsf _adcon1,5 //PCFG1
bsf _adcon1,4 //PCFG0
bsf _trisa,2 //adc ref-
bsf _trisa,3 //adc ref+
bsf _ansel,2 //analog in ref-
bsf _ansel,3 //analog in ref+
However, the ADC output is erratic indicating that the Vref isn't read from the pin (which is at 4.096V with Vcc being 5V).
What did I overlook?
Jan
jadiflow
Flowcode v5 User
Re: ADC Vref hardware setting
Post by jadiflow »
Nobody? I should add that when I reset the component property to use Vdd as ref all works as intended.
Jan
Hi Jan,
I have just looked into why enabling Vref+ within ADC properties (Right click ADC component on the panel and click Ext properties & change Vref option) is not working.
I have found a bug with PIC_CAL_ADC.c
If you make a backup copy and replace:
PIC_CAL_ADC.c that's in:
C:\Program Files (x86)\Flowcode\v5\CAL\PIC\ (If 64 bit windows)
or
C:\Program Files\Flowcode\v5\CAL\PIC(If 32 bit windows.)
With the attached file, then hopefully ADC should read correct with pin5 connected to a fixed voltage.
No C code is required and you can choose any ADC channel.
Tested with 16F883
PIC_CAL_ADC.c
(89.73 KiB) Downloaded 677 times
jadiflow
Flowcode v5 User
Post by jadiflow »
Martin, thank you! I cannot test it right now but will and report if there are other issues - but I trust this will fix it!
Jan
medelec35 wrote:Hi Jan,
or
Tested with 16F883
jadiflow
Flowcode v5 User
Post by jadiflow »
Better late than never - just got around to checking whether the Vref for the ADC works - and it indeed does, thanks again Martin!
But as is often the case, one answer brings up another question.
In the ADC dialog box there is a field where you can set the Vref voltage per 10mV chunks; for a 5V ref you would set that at 500.
I played with that setting (I am using a 4.096V ref) but it doesn't seem to make any difference in the application.
Is this only for the simulation runs?
Jan
Hi Jan,
The VRef Voltage Property effects the ReadAsVoltage and ReadAsString macros where you get a voltage out rather than a direct numeric ADC reading. Should work for both sim and download.
jadiflow
Flowcode v5 User
Post by jadiflow »
Clear.
Thanks,
Jan
