Need help with 2D Dashboard Panel screen image error
Posted: Sat Dec 12, 2015 10:29 am
by bernoulli
I am just getting started using FlowCode. I need help on why the 2D Dashboard Panel is not displaying the ruler image and component images. I am attaching to this post a screen image of how it is displayed on my monitor. I believe the black boxes should be numbers and the highlighted rectangular outline should be a 3x4 keypad.
I am using Win7 Pro, 32-bit operating system.
Thank you for your help.
Gary
Re: Need help with 2D Dashboard Panel screen image error
Posted: Sat Dec 12, 2015 12:45 pm
by kersing
Try switching the graphics engine.
Open the application settings ('View'->'Global Options', switch to TAB 'Application'). In the right bottom part of the dialog you can choose the 'Graphics engine'. Switch it to the other setting (to hardware if now set to software and vice versa) and restart Flowcode.
Posted: Sat Dec 12, 2015 4:00 pm
by EtsDriver
Or if above doesn't work, try re-installing completely. I've noticed at my current workplace, that for some reason, sometimes the installation doesn't complete fully and needs to be re-installed...
