Need help with 2D Dashboard Panel screen image error
bernoulli
Has thanked: 1 time
Post by bernoulli »
I am just getting started using FlowCode. I need help on why the 2D Dashboard Panel is not displaying the ruler image and component images. I am attaching to this post a screen image of how it is displayed on my monitor. I believe the black boxes should be numbers and the highlighted rectangular outline should be a 3x4 keypad.
I am using Win7 Pro, 32-bit operating system.
Thank you for your help.
Gary
2D Dashboard Panel Image.jpg (59.5 KiB) Viewed 2750 times
kersing
Has thanked: 553 times
Been thanked: 1081 times
Re: Need help with 2D Dashboard Panel screen image error
Post by kersing »
Try switching the graphics engine.
Open the application settings ('View'->'Global Options', switch to TAB 'Application'). In the right bottom part of the dialog you can choose the 'Graphics engine'. Switch it to the other setting (to hardware if now set to software and vice versa) and restart Flowcode.
― C.S. Lewis
EtsDriver
Has thanked: 345 times
Been thanked: 227 times
Post by EtsDriver »
Or if above doesn't work, try re-installing completely. I've noticed at my current workplace, that for some reason, sometimes the installation doesn't complete fully and needs to be re-installed...
