When I have Interrupts in a Program the simulation can become pretty frantic. ( I might be doing something wrong!)
It would be handy to be able to manually trigger Interrupts when i simulation mode... essentially a button press is seen as the interrupt.
Simulating Interupts - Manual triggering
Forum rules
Re: Simulating Interupts - Manual triggering
Hi Jay Dee,
The port interrupts can be triggered manually.
All you do is add a switch then assign it to for connection for the required interrupt.
Then pressing switch should trigger ISR macro
