Bugs Pic16f1933 up to Pic16f1939!
Has thanked: 1135 times
Been thanked: 299 times
Post by jgu1 »
Hi MM!
After have copy and overwrite the temporary from here: viewtopic.php?f=54&t=17032 I get following message when I choose pic16f1933 up to pic16f1939:
Unable to create microcontroller pic16f19xx as the definition file pic16f19xx. FCD is missing or corrupt 0x3
Line 179 char13 <in port :(
Ufortunately I have not backup the old file. have overwritten in my 2 laptop (thought the update was testet and sure).
Best regard
Jorgen
Re: Bugs Pic16f1933 up to Pic16f1939!
Hi Jorgen,
Just in case more targets are affected, I have attached all fcd files.
That saves you running a repair and loosing other updates.
At least then you can use the targets you mentioned.
FCD Files.zip
(1.36 MiB) Downloaded 288 times
Post by jgu1 »
Hi Martin!
Thank you, now I can use these target Again, it work, I am really gratefull for your help.
I hope if MM want to use the correction that I used i Next release of update, they have an extra look at theese files they doesn´t work :D
Thank´s Martin, have a nice evening.
BR
Jorgen
Thanks for letting us know of the problem. I have tested the files from the update and they seem to be working correctly for me. I will investigate further.
Can anybody else replicate this problem?
Rudi
Has thanked: 493 times
Been thanked: 187 times
Post by Rudi »
hi jorgen
have tested just in time the linked zip file and tested the pic16f1933.fcdx
178.    	<inplus>
179.   		<in port='0' pin='3' />
180.    	</inplus>
there is no mistake in the file, if you load it to the xml notedpad, then you can load without mistake too.
so my question is, have you perhabs make a "comment" like this..
<!-- my comments  -->
or have changed on line and forget the
perhabs you can upload your PIC16f1933.fcdx file, then can we look into yours problem.
@beny,
cant replicate this - picf1633.fcdx from the zip files look ok from format and load in FC6 without mistake.
(btw: perhabs the best timestamp for a tool like a fcdx editor? ;-) )
hope this helps
best wishes
rudi ;-)
Post by jgu1 »
Hi Ben, Martin and Rudi!
I think you deserve to get an update. I have tried uninstalling and installing FC6 again from scratch. After reinstall, I have overwritten with Ben´s "temporary" updated files FCD,CAL ect. and FC is runnig with Pic16f1933 up to Pic16f1939 Again without error. What have being going wrong I don´t know, something I maybe have done during the update. :?:
I am happy Again and look forward to get the BIG udate from MM :lol:
Thank´s guy´s
Br
Jorgen
This has just happened to me on my home laptop, hmmm.
Maybe a bad batch of files in the not so distant past?
I wonder if it's somehow Windows doing a installation repair and failing?
Either way it's troubling. :?
