Using 4 - 7 segment displays - Sync problem
A forum where Flowcode v6 user created components can be shared, discussed and reviewed.
JLeith
Has thanked: 146 times
Been thanked: 26 times
Post by JLeith »
Hello all
I was using a Quad 7 segment and everyting was working.
Then I thought I would like to use ( 4 ) 7 segments so I can disaply the info on two independent loactions.
I thought it should work.
I have ( 4 ) displays with PORT B shared and the common lead ( A0,A1,A2,A3)
For the simulation only the "Guest" add works.
When I press Guest Add all ( 4 ) of the display list the results ???
I have added a pictrure and also the Flowcode 6 program.
I had the Quad working on my Model Railway to display the train coming into the station, When I was playing I added a few more macro to play with.
Then the crash when I went to single 7 segments.
John
LCD and Push Button.fcfx
(80.27 KiB) Downloaded 514 times
(27.85 KiB) Downloaded 4768 times
Re: Using 4 - 7 segment displays - Sync problem
Hi John,
Here I have modified a flowchart to work with quad 7SEG LED's
If I was you I would go through the flowchart to see how 7SEG LED's work together.
JLeith
Post by JLeith »
Hello Martin
I hope the family is doing well. Over Christmas we have a new grandson ( Benjermine ). Dec 18th.
I read thru the link you posted and I could be 100% wrong but it is realted to the QUAD display. I used the Quad Display and I had great results. The issue came when I decided to use ( 4 ) single 7 segment displays ?
I will try and google more information and try to find a Flowcode video that uses ( 4 ) single LEDS.
I thought maby there was a glitch in Flowcode. Here is how I belive I have the single display connected.
The issue is that even if I send the value to segment 1 flowcode displays the value on all 4 segments ?
John
(23.55 KiB) Downloaded 4760 times
Hi John,
Family are well thanks, hope yours is too?
JLeith wrote:Over Christmas we have a new grandson ( Benjermine ). Dec 18th.
Congrats on the new edition. :)
JLeith wrote: read thru the link you posted and I could be 100% wrong but it is realted to the QUAD display
Yes but you can ADD the quad component and just use two of them.
It should work.
Its a similar principle with single as it is with quads.
You much only have one display at a time lit up.
So if you have four single 7seg displays 0 to 3.
Clear Digit 0, show digit 3
Delay 3ms
Clear Digit 3, show digit 2
Delay 3ms
Clear Digit 2, show digit 1
Delay 3ms
Clear Digit 1, show digit 0
Delay 3ms
repeat for ever
For the delay you could place the 7seg components within timer interrupt set for 300Hz
JLeith
Post by JLeith »
Hi Martin
I did some searching and I follow your information.
Using the Quad layout in Flowcode I can than use 2 sets of double 7 Segments and control them with the port settings.
From your information Flowcode is realy not able to control ( 4 ) individual displays and that is why they developed the Quad I suspect.
I will rebuild my desighn back to the Quad and when I had it working before I thought I could use seperate segements.
Thank you for taking the time to expain the on/off state.
All the best
John
Hi John.
no problem.
Reason for only having one 7seg LED pn at a time is because all the segments a to g are connected in parallel.
So if more than one are enabled at the same time then they would show the same digit.
Of segments a to g are cathodes then its the common anodes of each one connected to seperate pins.
Although using quad on your flowchart, you can use single on your hardware.
Before changing flowchart to quad I will see if I can get flowchart you posted working with single. 7segment LED's.
JLeith
Post by JLeith »
Hi Martin
I was able to get the Quad working and I will be developing the Hardware and see how it works on 2 segment displays.
Here is my working model.
I have 2 LCD displays from the Scoreboard layout that have the pins off.
The run 16..15...1 to 14. They didn't work in my PCB and for some reason I had 2 sitting in a box. I must of ordered them from EBAY and not checked.
Latest version Feb 3
(83.66 KiB) Downloaded 514 times
Hi John,
I have been testing multiple 7segs.
They work fine with hardware but unfortunately there is a simulation bug which I have reported.
So if you want simulation best stick with the quads for now.
Besides if using quads type then it simplifies flowchart since with single 7segs you must switch off 3 and only have one running at a time as shown earlier.
I have made a small mod to your flowchart so 7seg LED's should work better on hardware.
You should be able to use individual ones instead of quad on your hardware
LCD and Push Button 2.fcfx
(83.73 KiB) Downloaded 530 times
