Assembler variable values such as 'outdir'
gtc
Has thanked: 30 times
Been thanked: 15 times
Post by gtc »
Using Windows, Flowcode 6.1.
Where can I see the current value of an assembler variable such as 'outdir'.
Also, where in Flowcode are such variables' values set/mapped/changed?
Re: Assembler variable values such as 'outdir'
If you go to View -> Global options -> Locations tab then there are drop down arrows that show you the internal variables.
I'm not sure where the $(outdir) is set (probably a registry key) but the $(srcdir) and $(appdir) are the two we use a lot for components, compilation etc.
gtc
Post by gtc »
Thanks for the lightning quick reply!
I don't recall setting my outdir value, unless it was done during initial installation?
Reason I ask is that I was using a friend's FC V6 implementation today and the hex file was being written into some bizarre windows temp directory. I have no idea how that came about and neither does he.
Surely there must be an easy way of changing that variable's assignment?
Ok can you check the View -> Project Options -> Locations Tab.
The Send Compiler Output To should be set to
$(srcdir)
This should set the $(outdir) variable to equal your Flowcode project directory when you compile.
Let me know how you get on.
gtc
Post by gtc »
I take it you mean View -> Global Options -> Locations Tab (as before).
So, one uses the "..." button to select the desired directory. I'll try that when I next have access to his machine.
Yes sorry, I should look at things rather then using my memory :D
No you shouldn't have to do this for every project. If you type in the value $(srcdir) then this should default to your project directory and will change dynamically as you load different projects.
