bug with 16f88 - Resolved
hertz89
Been thanked: 3 times
Post by hertz89 »
hi
i have pic16f88 ..when try simple program for test the delay get bigger...i mean before the led start there are 300 msec delay
in real life the delay become 3 second! i thought the problem from the pic so i bought 3 more from other shop and same problem
i have pickit2 clone and it work fine for all my other mcu....i think the problem from flowcode 6
Flowcode1.fcfx
(4.26 KiB) Downloaded 337 times
Has thanked: 481 times
Been thanked: 699 times
Re: bug with 16f88
You have Project Options set to Internal RC Osc
Is that what you want?
Do you have an external crystal?
Internal RC will be very slow by default, but you also have Project Options->Clock Speed set to 4MHz, so the delay calculations in Flowcode will be wrong.
You can change the Internal RC Oscillator Frequency by writing to the OSCCON register, see Page 40 of PIC16F88 datasheet.
Leigh
hertz89
Re: bug with 16f88
Post by hertz89 »
hii
how do that in flowcode? could you give me the code?
Re: bug with 16f88
At the very start, so should be the first icon.
Place a C code block with
osccon=0x60;
(36.5 KiB) Downloaded 3666 times
It's not a Flowcode bug so moved topic from the Bugs section.
