I read temperature, do calculations according to datasheet but get incorrect values. Tried different ways of calculations (separating values into different variables, changing types) but still no success.
here's part of datasheet: here's macro of i2c reading of raw temperature here are calculations according to datasheet
x1 = ((ut - ac6) * ac5) >> 15
x2 = (mc << 11) / (x1 + md)
b5 = x1 + x2
t = (b5 + 8) >> 4ut, x1,x2,b5,t = long
ac5, ac6 = uint
mc, md = int
results in terminal are
ut=29358 t=434434 is also changes time to time around 434, 438, etc as I open windows to change inside temp.. so seems like it reads the temperature and not some fixed data.
where I could be wrong? I suppose that the problem may be in calculations and types.
help me to locate the problem, please.
Thank you in advance.
