Strings are cut if more as 10 byte send by * Param [solved]
Rudi
Has thanked: 493 times
Been thanked: 187 times
Post by Rudi »
FC 6.1.3.2 (18.02.2016)
hi
this was my base, and my solution for this.
but if i send more as 10 Bytes ( data + \0 ) then the string is cutting.
because the sbuffer is 20 ( sbuff[20] ) i think there can it be a bug in FC.
perhabs you can check it, would be fine
thank you.
best wishes
rudi ;-)
edit: solved
thanks Leigh, i edit the c code in FCM_helperFunc_X:
int (*lf) ();
lf = ( unsigned short *) FCL_PADDR;
lf("DODO1\n");
// old
// lf(FCL_SBUFF);
// new
lf(FCL_SBUFF, FCLsz_SBUFF);
think now i understand the principal with strings in FC better.
this local copy of strings is same theme with char++
if i want make char++ then i do not use the local copy,
you gave me this last year, i remember me ;-)
have test to make send struct now too, and do the work
will update the fcx later time and upload a solution for sending structs.
thank you!
best wishes
rudi ;-)
Has thanked: 481 times
Been thanked: 699 times
Re: Strings are cut if more as 10 byte send by * Parameter
Hi Rudi,
The issue is that when Flowcode macros have a string parameter the C code generated actually has two parameters, a string pointer plus the maximum string size. This string size is not being passed in your C code in FCM_helperFunc_X()
Leigh
ps. Things will be a bit clearer if you remove the local string copy in the macro
