[solved] PINGUINO Bootleader.... thanks MR RUDI
mossine
Has thanked: 12 times
Been thanked: 5 times
Post by mossine »
hi everyone
haw acn i using Flowcode with the PINGUINO Bootloader
my Cart PInguino is : 18F4550 - 20MHz
(47.91 KiB) Downloaded 15859 times
i cant programme with PYthon .. i like Flowcode
i was seeing this video about how to use bootloader and flowcode
https://www.youtube.com/watch?v=NFBWHMlCg94
thank you
Re: PINGUINO Bootleader
You should just be able to create a Flowcode program and then use the Pinguino software to transfer the hex file created from Flowcode to your hardware.
You might need to shift the hex file to allow for the Pinguino bootloader however there doesn't seem to be much information on this.
For our bootloaders we need to shift the code by either 0x800 or 0x1000.
To do this you can go into the Compiler options and add this to the beginning of the linker parameters
-rb 0x800
where 0x800 is the shift you need.
The linker parameters should end up looking like this.
-rb 0x800 -ld "$(appdir)compilers\pic\boostc\lib" libc_$(family:/12F/16F).lib rand_$(family:/12F/16F).lib float_$(family:/12F/16F).lib "$(target).obj" -t PIC$(chip:u) -d "$(outdir:~-1)" -p "$(target)" -swcs 6 2
The whole idea of the Pinguino is that you can use Arduino style code to program a PIC. If you are using Flowcode then you can talk to the chip directly with a PICkit so the Pinguino bootloader is not necessary.
An ECIO28P or ECIO40P is a 18F2455 and 18F4455 device with USB reprogramming and bootloader built in and ready to go, maybe this would be more suitable?
mossine
Post by mossine »
thank you Mr Benj .
i was do the same configuration but its not work
Unlike the microchip bootloader . its work without shifting the code . i think the problem in the Pinguino IDE
this is the Pinguino bootloader :
Bootloader_v4.14_18f4550_X20MHz.hex
(6.99 KiB) Downloaded 819 times
and i shift code by either 0x0A30 and use other 0x1000 -....
the result is nothing
i like to programme with flowcode it's more suitable , but Pinguino bootloader is necessary for me .
i waiting for your help , thank you so much Mr Benj .
cordially mossine
mossine
Post by mossine »
hi everyone
i'm waiting for news about adapting flowcode with pinguino kits
i hope the developers of flowcode found a solutions .
thanks for all
Rudi
Has thanked: 493 times
Been thanked: 187 times
Post by Rudi »
mossine wrote:hi everyone ..
..and i shift code by either 0x0A30 and use other 0x1000 -....
cheers ;-)
not sure but give this a try:
# ENTRY address is the end of bootloader / start of user's application
# ENTRY must be a multiple of 1024 because :
# 1/ flash must be erased before any write,
# 2/ some PICs can only erase 1024-byte long blocks
ENTRY		= 0x0C00
and shift with this try
-rb 0x0C00
info1
info2
best wishes
rudi ;-)
btw which Software "programmer" you use for download the firmware(not bootloader hex)?
did it find the "bootloader" if you push to bootloader mode?
edit: example stand-alone uploader (uploader8.py)
info3
info4
you need then python
other step would be, compile a bootloader ( makefile ) and change the shift address to your need, that would be a second solution.
mossine
Post by mossine »
hi everyone .
thank you for your explanation . To bring the point of my view : i was used the microchip bootloader and use PIC18F4550 it's like pinguino,except some differents ;and sometimes created programmes with MikroC or created with FLOWCODE .Honestly i like programming with flowcode .
when i uploaded the hex file into my kit " 18F4550 starter kit with microship bootloader " ,its works good .
Unlike application on "Pinguino" with Pinguino Bootloader .. its not work ;Although shifting the code to address .
but i think this is the end of my attempts for adapting between flowcode and PINGUINO , because a Developer on Pinguino says that's :
Bonsoir Mohssine,
N'espères pas pouvoir uploader des applis FLOWCODE sur un 18f4550 + bootloader v4.14. Après vérification ce bootloader n'a pas été conçu avec cette possibilité.
Utilises plutôt le bootloader Microchip et PDFSUSB.exe pour télécharger les applis Flowcode décalés de 0x0800.
A bientôt
https://translate.google.com
Do not hope to be able to upload FLOWCODE apps on a 18f4550 bootloader + v4.14. After checking the bootloader was not designed with this possibility.
Rather using the Microchip and PDFSUSB.exe bootloader to download apps Flowcode offset 0x0800.
See you soon
i don't think so . i know it is possible to do this work " adapting " but i'm just a beginner to know all that's ..
even your explanation i try to know how to applied ..thank you for your explanation
mossine
Post by mossine »
by Rudi » Wed May 11, 2016 10:15 pm
i loved creating flowcode programs and upload the hex file of these programs using IDE pinguino: download directly hex option,see below option :
(39.03 KiB) Downloaded 15760 times
yes its works will . i was installed pinguino drivers on my computer, i can creating programms with python IDE and upload to pinguino its works .
but i like to try with hex created by flowcode that's the problem
thank you
Rudi
Post by Rudi »
mossine wrote:
Bonsoir Mohssine,
A bientôt
aaahhh
think, i understand now better:
your pinguino uploader works well?
and the shift address is 0x0800 in python ide?
so give this a try:
compile / link ( only this ) in Flowcode with this then:
-rb 0x0800
then try to upload with the pinguino tool this hex
if work, then we know, that "0x0800 is your friend"
then you need a flash programm, that support 0x0800 as bootloader. ( mloader is standard in FC , not sure but think support 0x0000 .. 0x1000 ...)
btw using the Microchip and PDFSUSB.exe is possible too, the one that must change is,
that the tool "see at 0x0800" for your application code.
or you can use the pinguino flasher if support by command in flowcode btw.
if pinguino downloader is named "myflasher.py" then if you installed python on your desktop
then you can call "python myflasher.py "yourhexfile.hex"
or with other words:
you can use the environment variables in flowcode too:
so look at "$(outdir)$(target).hex"
thats the hex file that flowcode create.
hope this helps.
best wishes
rudi ;-)
Rudi
Post by Rudi »
other question:
do you want to upload by a bootloader or do you want to flash the chip at 0x0000
the bootloader helps you, to upload a hex file by simple connect the chip with a software flasher
the bootloader must installed first time with flash utentsily like PicKit2, PicKit3 and other.
if the bootloader is installed, then the applicaction code can upload by this helper on the chip.
if you want to upload your created hex file in flowcode without a bootloader, then you flash the hex without a shift address,
but then you need the picKit2, picKit3 or other to connect to the chip by SPI ( ISP ) ..
what do you want to do ? :mrgreen:
mossine
Post by mossine »
hi everyone .
thank you Mr Rudi .
that's what i want to do exactly ,
-rb 0x0800
i try all that before, no change no things work
it was failed trying, with alot of address..
i think the Pinguino drivers installed in windows not compatible with uploaded programmes like : Mloader - Microchip PDFSUSB.exe - FarnellProg ........
(62.05 KiB) Downloaded 15707 times
Rudi
Post by Rudi »
cheers,
When the RESET button is pressed, the bootloader waits until a program is uploaded.
src
push the reset button
wait 3 seconds
when the run led is off click on the upload button in Pinguino IDE
After 5 seconds the run led will light, the user program is running
info version 2 (PIC18F4550)
do you press the reset button on start for "bootloader mode" while Soft Flasher search the devide on VID, PID ?
or how you flash with pinguino ide the hex? have you an extra boot jumper on your board?
you sayed, the pc found the bootloader driver on your system,
can you look at system and device manager that you have a "bootloader" device in device manager and how is this named in the system?
can you post PID and VID of them, too?
than perhabs can use the src from microchips pdfusb and programm "bootloader scanner" on which adress the bootloader on your pinguino is listening.
best wishes
rudi ;-)
Rudi
Post by Rudi »
V2
try 0x2000
V3
try 0x0800
V4
try 0x0C00
where you get the bootloader software?
was this on PIC18F4550 installed?
there must be an info, where the APP Start Addresss is
then you can link with -rb APPSTARTADDRESS
in Flowcode your flowcode and if the flash programm support command line
then you can use it like pre post descriped ( example python )
flowcode generally support your way, but you must know,
on which address the bootloader is talking with flash programm
and you must switch to bootoader mode like Press Reset Button.
or ( here in PIC18F2550 ) i push RC2 for bootloader mode
// example 0x0800
CODEPAGE NAME=apppage START=0x0800 END=0x0801
best wishes
rudi ;-)
Rudi
Post by Rudi »
have you test the standalone programmer
this is the tool you need for programm the pinguino then in flowcode.
compare your founds in device manager with this:
VENDOR_ID                       =    0x04D8    # Microchip License
PRODUCT_ID                      =    0xFEAA    # Pinguino Sub-License
where
VID = 0x04D8
PID = 0xFEAA
do this match?
then test your programmer from command line,
be sure you have installed python
and your device is in bootloader mode!
memstart = 0x0C00 # bootloader offset
so please, link your flowchart in flowcode with -rb 0x0C00
then test, switch to bootloader boot, then run like this...
c:\python27\python c:\yourflashtool\programmer8.py c:\yourhexlocation\flowcode.hex
and here the correct command:
#    Usage: programmer8.py path/filename.hex target
#    ex : programmer8.py blink.hex 18f47j53
so have a look to the supported devices..
# Table with supported USB devices
# device_id:[PIC name, flash size(in bytes), eeprom size (in bytes)]
devices_table = \
        0x4740: ['18f13k50'     , 0x02000, 0x80 ],
        0x4700: ['18lf13k50'    , 0x02000, 0x80 ],
        0x4760: ['18f14k50'     , 0x04000, 0xFF ],
        0x4720: ['18f14k50'     , 0x04000, 0xFF ],
        0x2420: ['18f2450'      , 0x04000, 0x00 ],
        0x1260: ['18f2455'      , 0x06000, 0xFF ],
        0x2A60: ['18f2458'      , 0x06000, 0xFF ],
        0x4C00: ['18f24J50'     , 0x04000, 0x00 ],
        0x4CC0: ['18lf24J50'    , 0x04000, 0x00 ],
        0x1240: ['18f2550'      , 0x08000, 0xFF ],
        0x2A40: ['18f2553'      , 0x08000, 0xFF ],
        0x4C20: ['18f25J50'     , 0x08000, 0x00 ],
        0x4CE0: ['18lf25J50'    , 0x08000, 0x00 ],
        0x5C20: ['18f25k50'     , 0x08000, 0xFF ],
        0x5CA0: ['18lf25k50'    , 0x08000, 0xFF ],
        0x4C40: ['18f26J50'     , 0x10000, 0x00 ],
        0x4D00: ['18lf26J50'    , 0x10000, 0x00 ],
        0x5860: ['18f27j53'     , 0x20000, 0x00 ],
        0x1200: ['18f4450'      , 0x04000, 0x00 ],
        0x1220: ['18f4455'      , 0x06000, 0x00 ],
        0x2A20: ['18f4458'      , 0x06000, 0xFF ],
        0x4C60: ['18f44J50'     , 0x04000, 0x00 ],
        0x4D20: ['18lf44J50'    , 0x04000, 0x00 ],
        0x1200: ['18f4550'      , 0x08000, 0xFF ],
        0x2A00: ['18f4553'      , 0x08000, 0xFF ],
        0x4C80: ['18f45J50'     , 0x08000, 0x00 ],
        0x4D40: ['18lf45J50'    , 0x08000, 0x00 ],
        0x4CA0: ['18f46J50'     , 0x10000, 0x00 ],
        0x4D60: ['18f46J50'     , 0x10000, 0x00 ],
        0x58E0: ['18f47j53'     , 0x20000, 0x00 ],
        0x4100: ['18f65J50'     , 0x08000, 0x00 ],
        0x1560: ['18f66J50'     , 0x10000, 0x00 ],
        0x4160: ['18f66J55'     , 0x18000, 0x00 ],
        0x4180: ['18f67J50'     , 0x20000, 0x00 ],
        0x41A0: ['18f85J50'     , 0x08000, 0x00 ],
        0x41E0: ['18f86J50'     , 0x10000, 0x00 ],
        0x1F40: ['18f86J55'     , 0x18000, 0x00 ],
        0x4220: ['18f87J50'     , 0x20000, 0x00 ]
and then if you use the PIC18F4550
c:\python27\python c:\yourflashtool\programmer8.py c:\yourhexlocation\flowcode.hex 18f4550
if not working
while True:
        device = getDevice(VENDOR_ID, PRODUCT_ID)
        if device == ERR_DEVICE_NOT_FOUND:
            print "Pinguino not connected"
        else:
            print "Pinguino found !"
            break
you will get "Pinguino not connected", check that you are in bootloader mode
if you get "Pinguino found"
then you make the goal.
solution if not found,
last step that i can give you then,
you can change the PID, VID in py file to your installed in device manager and try again
this where my last inspiration for this ;-) .. be sure your device is in bootloader mode! /reset button or like you configured.
best wishes
rudi ;-)
ps
do not use the uploader8.py
this does not work with microchip modified HID bootloader sources ( last 2 years )
mossine
Post by mossine »
sorry for not completing my clarification of my problem because an interruption of net sudden .
the thing who want to complete is uploading a screen capture win my IDE python works .and this is my Pinguino kite :
this are a reports of pinguino IDE :
1 - compile example and upload :
(39.96 KiB) Downloaded 5887 times
(36.72 KiB) Downloaded 5887 times
2 - upload directly the same hex file with this option :
without compiling
(37.8 KiB) Downloaded 5887 times
continued ........
mossine
Post by mossine »
continued
2 - upload directly the same hex file :
without compiling
(18.1 KiB) Downloaded 15625 times
upload directly flowcode hex file :
this is the error in msg
(20.25 KiB) Downloaded 15625 times
To clarify i'm not a developer; just a beginner, and trying to understand your Recommendations.
i use the version V14,4 for pinguino bootloader
this is a video of my Pinguino kite :
https://youtu.be/QkU2xJ5qsSI
(47.91 KiB) Downloaded 15625 times
thank you for your Mr Rudi . i'm going to try apply your guidance
Rudi
Post by Rudi »
hi
thank you for infos..
i write just in time short perhabs you are on pc and can use the info:
see the start from 0x00C00
so please have a try in flowcode in link command ( compiler options ) with -rb 0x00C00
i am not sure, because it write from 0x00C00 to 0x08000
but have a try, please.
will write at weekend ( think can be sunday ) again.
best wishes
rudi ;-)
mossine
Post by mossine »
hi everyone .
thank you Mr Rudi .
To inform you . i was opened this subfolders with IDLE :
(19.8 KiB) Downloaded 15606 times
(51.05 KiB) Downloaded 5868 times
tools.py
#!/usr/bin/env python
#-*- coding: utf-8 -*-
import logging
import time
import traceback
class Debugger(object):
    @classmethod
    def debug_method(self, f):
        def inset(*args, **kwaargs):
            logging.info("Starting '%s' from '%s'" % (f.__name__, f.__module__))
            t1 = time.time()
            try:
                ret = f(*args, **kwaargs)
            except:
                logging.info(traceback.format_exc())
                return
            t2 = time.time()
            logging.info("Time spent for '%s': %.2f s" % (f.__name__, t2-t1))
            logging.info("Ending '%s'" % f.__name__)
            return ret
        return inset
uploader.py
import usb
import sys
import logging
import os
#import debugger
from ..tools import Debugger
class baseUploader(object):
    # Hex format record types
    # Data_Record = 00
    # End_Of_File_Record = 01
    # Extended_Segment_Address_Record = 02
    # Start_Segment_Address_Record = 03
    # Extended_Linear_Address_Record = 04
    # Start_Linear_Address_Record = 05
    # Python3 compatibility (octals)
    Data_Record                     = 0o0
    End_Of_File_Record              = 0o1
    Extended_Segment_Address_Record = 0o2
    Start_Segment_Address_Record    = 0o3
    Extended_Linear_Address_Record  = 0o4
    Start_Linear_Address_Record     = 0o5
    # Error codes returned by various functions
    ERR_NONE                        = 100
    ERR_CMD_ARG                     = 101
    ERR_CMD_UNKNOWN                 = 102
    ERR_DEVICE_NOT_FOUND            = 103
    ERR_USB_INIT1                   = 104
    ERR_USB_INIT2                   = 105
    ERR_USB_OPEN                    = 106
    ERR_USB_WRITE                   = 107
    ERR_USB_READ                    = 108
    ERR_HEX_OPEN                    = 109
    ERR_HEX_STAT                    = 110
    ERR_HEX_MMAP                    = 111
    ERR_HEX_SYNTAX                  = 112
    ERR_HEX_CHECKSUM                = 113
    ERR_HEX_RECORD                  = 114
    ERR_VERIFY                      = 115
    ERR_EOL                         = 116
    ERR_USB_ERASE                   = 117
    # Configuration
    INTERFACE_ID                    = 0x00
    ACTIVE_CONFIG                   = 0x01
    VSC_ACTIVE_CONFIG               = 0x02
    # def __init__(self, hexfile, board):
        # self.report = []
    def add_report(self, message):
        """ display message in the log window """
        self.report.append(message)
        # DEBUGGING MESSAGE
        logging.info(message)
    def getDevice(self, board):
        """ Scans connected USB devices until it finds a Pinguino board """
        logging.info("Looking for a Pinguino device ...")
        busses = usb.busses()
        for bus in busses:
            for device in bus.devices:
                logging.info("Found device 0x%04X:0x%04X" % (device.idVendor, device.idProduct))
                if (device.idVendor, device.idProduct) == (board.vendor, board.product):
                    self.configuration = device.configurations[0]
                    logging.info("Configuration = %s" % self.configuration)
                    self.interface = self.configuration.interfaces[0][0]
                    logging.info("Interface = %s" % self.interface)
                    self.endpoints = []
                    self.pipes = []
                    for ep in self.interface.endpoints:
                        self.endpoints.append(ep)
                        self.pipes.append(ep.address)
                    if board.bldr == "boot2":
                        self.ACTIVE_CONFIG = self.VSC_ACTIVE_CONFIG
                    return device
        return self.ERR_DEVICE_NOT_FOUND
    def initDevice(self, device):
        """ Init a Pinguino device """
        handle = device.open()
        if handle:
            logging.info("OS is %s" % os.getenv("PINGUINO_OS_NAME"))
            if os.getenv("PINGUINO_OS_NAME") == "linux":
                if device.idProduct == 0x003C: #self.P32_ID:
                    # make sure the hid kernel driver is not active
                    # functionality not available on Darwin or Windows
                    handle.detachKernelDriver(self.INTERFACE_ID)
                    logging.info("Kernel driver detached")
            #handle.setConfiguration(self.configuration)
            handle.setConfiguration(self.ACTIVE_CONFIG)
            logging.info("Configuration set")
            #handle.claimInterface(self.interface)
            handle.claimInterface(self.INTERFACE_ID)
            logging.info("Interface claimed")
            logging.info("Everything OK so far")
            return handle
        return self.ERR_USB_INIT1
    def closeDevice(self, handle):
        """ Close currently-open USB device """
        try:
            handle.releaseInterface()
        except Exception as e:
            logging.info(e)
            pass
        logging.info("Device closed")
class Uploader(object):
    """Universal uploader class"""
        #debugger.Debugger(sys)
        self.hexfile = hexfile
        #self.filename = hexfile
        self.board = board
        if board.bldr == "noboot":
            # TODO : interface here something like PICpgm (http://www.members.aon.at/electronics/pic/picpgm/)
            #self.logwindow("You choose a board without bootloader.\nYou should either change your board type\nor use a programmer to upload your application on your board", 1)
            raise Exception("You choose a board without bootloader.\nYou should either change your board type\nor use a programmer to upload your application on your board")
        elif board.bldr == "boot2":
            from uploaderVSC import uploaderVSC as Uploader
        #elif board.bldr == 'boot3':
        #    self.uploader = self.uploaderDLN(*parameters)
        elif board.bldr == "boot4":
            from uploader8 import uploader8 as Uploader
        elif board.bldr == "microchip":
            from uploader32 import uploader32 as Uploader
        #self.uploader = Uploader(hexfile, board)
        self.uploader = Uploader()
    @Debugger.debug_method
    def upload(self):
        self.uploader.report = []
        self.uploader.uploadDevice(self.hexfile, self.board)
        return self.uploader.report
uploader8.py
#-*- coding: iso-8859-15 -*-
    Pinguino Universal Uploader
    Author:          Regis Blanchot <rblanchot@gmail.com>
    Last release:    2012-04-20
    This library is free software you can redistribute it and/or
    modify it under the terms of the GNU Lesser General Public
    License as published by the Free Software Foundation; either
    version 2.1 of the License, or (at your option) any later version.
    This library is distributed in the hope that it will be useful,
    but WITHOUT ANY WARRANTY; without even the implied warranty of
    MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
    Lesser General Public License for more details.
    You should have received a copy of the GNU Lesser General Public
    License along with this library; if not, write to the Free Software
    Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston,
    MA  02110-1301  USA
# This class is based on :
# - Diolan USB bootloader licenced (LGPL) by Diolan <http://www.diolan.com>
# - jallib USB bootloader licenced (BSD) by Albert Faber
# See also http://wiki.erazor-zone.de/wiki:projects:python:pyusb:pydoc
# Pinguino Device Descriptors : lsusb -v -d 04d8:feaa
#import sys
import os
#import usb            # checked in check.py
from uploader import baseUploader
class uploader8(baseUploader):
    """ upload .hex into pinguino device """
    # General Data Packet Structure (usbBuf)
    #    __________________
    #    |    COMMAND     |   0       [CMD]
    #    |      LEN       |   1       [LEN]
    #    |     ADDRL      |   2       [        ]  [addrl]
    #    |     ADDRH      |   3       [ADR.pAdr]: [addrh]
    #    |     ADDRU      |   4       [        ]  [addru]
    #    |                |   5       [DATA]
    #    .      DATA      .
    #    |                |   62
    #    |________________|   63
    BOOT_CMD                        =    0
    BOOT_CMD_LEN                    =    1
    BOOT_ADDR_LO                    =    2
    BOOT_ADDR_HI                    =    3
    BOOT_ADDR_UP                    =    4
    BOOT_DATA_START                 =    5
    BOOT_DEV1                       =    5
    BOOT_DEV2                       =    6
    BOOT_VER_MINOR                  =    2
    BOOT_VER_MAJOR                  =    3
    BOOT_SIZE                       =    1
    # Bootloader commands
    READ_VERSION_CMD                =    0x00
    READ_FLASH_CMD                  =    0x01
    WRITE_FLASH_CMD                 =    0x02
    ERASE_FLASH_CMD                 =    0x03
    #READ_EEDATA_CMD                =    0x04
    #WRITE_EEDATA_CMD               =    0x05
    #READ_CONFIG_CMD                =    0x06
    #WRITE_CONFIG_CMD               =    0x07
    RESET_CMD                       =    0xFF
    # Data Block's size to write
    DATABLOCKSIZE                   =    32
    # USB Packet size
    MAXPACKETSIZE                   =    64
    # bulk endpoints
    IN_EP                           =    0x81    # endpoint for Bulk reads
    OUT_EP                          =    0x01    # endpoint for Bulk writes
    # configuration
    # RB 2015-03-20 : moved to uploader.py
    #ACTIVE_CONFIG                   =    0x01
    #INTERFACE_ID                    =    0x00
    TIMEOUT                         =    10000       # 1200
    # Table with Microchip 8-bit USB devices
    # device_id:[PIC name]
    devices_table = \
        0x4740: ['18f13k50'],
        0x4700: ['18lf13k50'],
        0x4760: ['18f14k50'],
        0x4720: ['18f14k50'],
        0x2420: ['18f2450'],
        0x1260: ['18f2455'],
        0x2A60: ['18f2458'],
        0x4C00: ['18f24j50'],
        0x4CC0: ['18lf24j50'],
        0x5C60: ['18f24k50'],
        0x5CE0: ['18lf24k50'],
        0x1240: ['18f2550'],
        0x2A40: ['18f2553'],
        0x4C20: ['18f25j50'],
        0x4CE0: ['18lf25j50'],
        0x5C20: ['18f25k50'],
        0x5CA0: ['18lf25k50'],
        0x4C40: ['18f26j50'],
        0x4D00: ['18lf26j50'],
        0x5860: ['18f27j53'],
        0x1200: ['18f4450'],
        0x1220: ['18f4455'],
        0x2A20: ['18f4458'],
        0x4C60: ['18f44j50'],
        0x4D20: ['18lf44j50'],
        0x1200: ['18f4550'],
        0x2A00: ['18f4553'],
        0x4C80: ['18f45j50'],
        0x4D40: ['18lf45j50'],
        0x5C00: ['18f45k50'],
        0x5C80: ['18lf45k50'],
        0x4CA0: ['18f46j50'],
        0x4D60: ['18lf46j50'],
        0x58E0: ['18f47j53'],
        0x4100: ['18f65j50'],
        0x1560: ['18f66j50'],
        0x4160: ['18f66j55'],
        0x4180: ['18f67j50'],
        0x41A0: ['18f85j50'],
        0x41E0: ['18f86j50'],
        0x1F40: ['18f86j55'],
        0x4220: ['18f87j50']
    def sendCommand(self, handle, usbBuf):
        """ send command to the bootloader """
        #self.txtWrite('[%s]' % ', '.join(map(hex, usbBuf)))
        sent_bytes = handle.bulkWrite(self.OUT_EP, usbBuf, self.TIMEOUT)
        #self.txtWrite(str(sent_bytes))
        if sent_bytes == len(usbBuf):
            #self.txtWrite("Block issued without problem.")
            # whatever is returned, USB packet size is always
            # 64 bytes long in high speed mode
            return handle.bulkRead(self.IN_EP, self.MAXPACKETSIZE, self.TIMEOUT)
        return self.ERR_USB_WRITE
    def resetDevice(self, handle):
        """ reset device """
        #usbBuf = [self.RESET_DEVICE_CMD] * self.MAXPACKETSIZE
        usbBuf = [0] * self.MAXPACKETSIZE
        # command code
        usbBuf[self.BOOT_CMD] = self.RESET_CMD
        # write data packet
        #usbBuf = self.sendCommand(usbBuf)
        try:
        except:
        return self.ERR_NONE
    def getVersion(self, handle):
        """ get bootloader version """
        # command code
        usbBuf[self.BOOT_CMD] = self.READ_VERSION_CMD
        # write data packet and get response
        usbBuf = self.sendCommand(handle, usbBuf)
        if usbBuf == self.ERR_USB_WRITE :
        # major.minor
        return str(usbBuf[self.BOOT_VER_MAJOR]) + "." + \
               str(usbBuf[self.BOOT_VER_MINOR])
    def getDeviceID(self, handle):
        """ read 2-byte device ID from location 0x3FFFFE """
        usbBuf = self.readFlash(handle, 0x3FFFFE, 2)
        if usbBuf == self.ERR_USB_WRITE:
        #print "BUFFER =", usbBuf
        dev1 = usbBuf[self.BOOT_DEV1]
        #print "DEV1 =", dev1
        dev2 = usbBuf[self.BOOT_DEV2]
        #print "DEV2 =", dev2
        device_id = (int(dev2) << 8) + int(dev1)
        #print device_id
        device_rev = device_id & 0x001F
        # mask revision number
        return device_id  & 0xFFE0
    def getDeviceName(self, device_id):
        for n in self.devices_table:
            if n == device_id:
                return self.devices_table[n][0]
    def eraseFlash(self, handle, address, numBlocks):
        """ erase numBlocks of flash memory """
        # command code
        usbBuf[self.BOOT_CMD] = self.ERASE_FLASH_CMD
        # number of blocks to erase
        usbBuf[self.BOOT_SIZE] = numBlocks
        # block address
        usbBuf[self.BOOT_ADDR_LO] = (address      ) & 0xFF
        usbBuf[self.BOOT_ADDR_HI] = (address >> 8 ) & 0xFF
        usbBuf[self.BOOT_ADDR_UP] = (address >> 16) & 0xFF
        # write data packet
        #return self.sendCommand(usbBuf)
    def readFlash(self, handle, address, length):
        """ read a block of flash """
        # command code
        usbBuf[self.BOOT_CMD] = self.READ_FLASH_CMD
        # size of block in bytes
        usbBuf[self.BOOT_CMD_LEN] = length
        # address of the block
        # send request to the bootloader
        return self.sendCommand(handle, usbBuf)
        #handle.bulkWrite(self.OUT_EP, usbBuf, self.TIMEOUT)
        #return handle.bulkRead(self.IN_EP, self.BOOT_DATA_START + length, self.TIMEOUT)
    def writeFlash(self, handle, address, datablock):
        """ write a block of code
            first 5 bytes are for block description (BOOT_CMD, BOOT_CMD_LEN and BOOT_ADDR)
            data block size should be of DATABLOCKSIZE bytes
            total length is then DATABLOCKSIZE + 5 """
        usbBuf = [0xFF] * self.MAXPACKETSIZE
        # command code
        usbBuf[self.BOOT_CMD] = self.WRITE_FLASH_CMD
        # size of block
        usbBuf[self.BOOT_CMD_LEN] = len(datablock)
        # block's address
        # add data to the packet
        #self.txtWrite(hex(address))
        for i in range(len(datablock)):
            #self.txtWrite(hex(datablock[i]))
            usbBuf[self.BOOT_DATA_START + i] = datablock[i]
        # write data packet on usb device
        #print usbBuf
        #print usbBuf
        #if usbBuf == self.ERR_USB_WRITE :
        #    self.txtWrite("Write error")
    def writeHex(self, handle, filename, board):
        """ Parse the Hex File Format and send data to usb device """
        [0]     Start code, one character, an ASCII colon ':'.
        [1:3]   Byte count, two hex digits, a number of bytes (hex digit pairs) in the data field. 16 (0x10) or 32 (0x20) bytes of data are the usual compromise values between line length and address overhead.
        [3:7]   Address, four hex digits, a 16-bit address of the beginning of the memory position for the data. Limited to 64 kilobytes, the limit is worked around by specifying higher bits via additional record types. This address is big endian.
        [7:9]   Record type, two hex digits, 00 to 05, defining the type of the data field.
        [9:*]   Data, a sequence of n bytes of the data themselves, represented by 2n hex digits.
        [*:*]   Checksum, two hex digits - the least significant byte of the two's complement of the sum of the values of all fields except fields 1 and 6 (Start code ":" byte and two hex digits of the Checksum). It is calculated by adding together the hex-encoded bytes (hex digit pairs), then leaving only the least significant byte of the result, and making a 2's complement (either by subtracting the byte from 0x100, or inverting it by XOR-ing with 0xFF and adding 0x01). If you are not working with 8-bit variables, you must suppress the overflow by AND-ing the result with 0xFF. The overflow may occur since both 0x100-0 and (0x00 XOR 0xFF)+1 equal 0x100. If the checksum is correctly calculated, adding all the bytes (the Byte count, both bytes in Address, the Record type, each Data byte and the Checksum) together will always result in a value wherein the least significant byte is zero (0x00).
                For example, on :0300300002337A1E
                03 + 00 + 30 + 00 + 02 + 33 + 7A = E2, 2's complement is 1E
        data        = []
        old_address = 0 # or board.memstart ?
        max_address = 0
        address_Hi  = 0
        codesize    = 0
        # size of erased block
        # Pinguino x6j50 or x7j53, erased blocks are 1024-byte long
        if ("j" or "J") in board.proc :
            #self.add_report("x6j50, x6j53 or x7j53 chip")
            erasedBlockSize = 1024
        # Pinguino x455, x550 or x5k50, erased blocks are 64-byte long
        else:
            #self.add_report("x455, x550 or x5k50 chip")
            erasedBlockSize = 64
        # image of the whole PIC memory (above memstart)
        for i in range(board.memend - board.memstart):
            data.append(0xFF)
        # read hex file
        hexfile = open(filename,'r')
        lines = hexfile.readlines()
        hexfile.close()
        # calculate checksum and max_address
        for line in lines:
            byte_count = int(line[1:3], 16)
            # lower 16 bits (bits 0-15) of the data address
            address_Lo = int(line[3:7], 16)
            record_type= int(line[7:9], 16)
            # checksum calculation
            end = 9 + byte_count * 2 # position of checksum at end of line
            checksum = int(line[end:end+2], 16)
            cs = 0
            i = 1
            while i < end:
                cs = cs + (0x100 - int(line[i:i+2], 16) ) & 0xff # not(i)
                i = i + 2
            if checksum != cs:
                return self.ERR_HEX_CHECKSUM
            # extended linear address record
            if record_type == self.Extended_Linear_Address_Record:
                # upper 16 bits (bits 16-31) of the data address
                address_Hi = int(line[9:13], 16) << 16
            # data record
            elif record_type == self.Data_Record:
                address = address_Hi + address_Lo
                # max address
                if (address > old_address) and (address < board.memend):
                    max_address = address + byte_count
                    old_address = address
                # code size
                if (address >= board.memstart) and (address < board.memend):
                    codesize = codesize + byte_count
                # data append
                for i in range(byte_count):
                    #Caution : addresses are not always contiguous
                    #data.append(int(line[9 + (2 * i) : 11 + (2 * i)], 16))
                    data[address - board.memstart + i] = int(line[9 + (2 * i) : 11 + (2 * i)], 16)
            # end of file record
            elif record_type == self.End_Of_File_Record:
                break
            # unsupported record type
            else:
                return self.ERR_HEX_RECORD
        # max_address must be divisible by self.DATABLOCKSIZE
        max_address = max_address + erasedBlockSize - (max_address % erasedBlockSize)
        # erase memory from board.memstart to max_address
        numBlocksMax = (board.memend - board.memstart) / erasedBlockSize
        numBlocks    = (max_address - board.memstart) / erasedBlockSize
        if numBlocks > numBlocksMax:
            return self.ERR_USB_ERASE
        if numBlocks < 256:
            self.eraseFlash(handle, board.memstart, numBlocks)
        else:
            numBlocks = numBlocks - 255
            upperAddress = board.memstart + 255 * erasedBlockSize
            # from board.memstart to board.memstart + 255 x 64 = 0x3FC0
            self.eraseFlash(handle, board.memstart, 255)
            # erase flash memory from board.memstart + 0x3FC0 to max_address
            self.eraseFlash(handle, upperAddress, numBlocks)
        # write blocks of DATABLOCKSIZE bytes
        for addr in range(board.memstart, max_address, self.DATABLOCKSIZE):
            index = addr - board.memstart
            self.writeFlash(handle, addr, data[index:index+self.DATABLOCKSIZE])
        self.add_report("%d bytes written." % codesize)
    #def writeHex(self):
    def uploadDevice(self, filename, board):
        # check file to upload
        if filename == '':
            self.add_report("No program to write")
            self.closeDevice(handle)
            return
        hexfile = open(filename, 'r')
        if hexfile == "":
            self.add_report("Unable to open %s" % filename)
            return
        hexfile.close()
        # search for a Pinguino board
        device = self.getDevice(board)
        if device == self.ERR_DEVICE_NOT_FOUND:
            self.add_report("Pinguino not found")
            self.add_report("If your device is connected,")
            self.add_report("press the Reset button to switch to bootloader mode.")
            return
        self.add_report("Pinguino found ...")
        handle = self.initDevice(device)
        if handle == self.ERR_USB_INIT1:
            self.add_report("Upload not possible")
            self.add_report("Try to restart the bootloader mode")
            return
        # find out the processor
        device_id = self.getDeviceID(handle)
        proc = self.getDeviceName(device_id)
        self.add_report(" - with PIC%s (id=%X)" % (proc, device_id))
        if proc != board.proc:
            self.add_report("Aborting: program compiled for %s but device has %s" % (board.proc, proc))
            return
        # find out flash memory size
        memfree = board.memend - board.memstart;
        self.add_report(" - with %d bytes free (%d KB)" % (memfree, memfree/1024))
        self.add_report("   from 0x%05X to 0x%05X" % (board.memstart, board.memend))
        # find out bootloader version
        #product = handle.getString(device.iProduct, 30)
        #manufacturer = handle.getString(device.iManufacturer, 30)
        self.add_report(" - with USB bootloader v%s" % self.getVersion(handle))
        # start writing
        self.add_report("Uploading user program ...")
        status = self.writeHex(handle, filename, board)
        if status == self.ERR_HEX_RECORD:
            self.add_report("Aborting: record error")
            return
        elif status == self.ERR_HEX_CHECKSUM:
            self.add_report("Aborting: checksum error")
            return
        elif status == self.ERR_USB_ERASE:
            self.add_report("Aborting: erase error")
            return
        elif status == self.ERR_NONE:
            self.add_report(os.path.basename(filename) + " successfully uploaded")
        # reset and start start user's app.
            #self.txtWrite("Resetting ...")
            self.add_report("Starting user program ...")
            self.resetDevice(handle)
            return
        else:
            self.add_report("Aborting: unknown error")
            return
Rudi
Post by Rudi »
hi
few question preview, perhabs this helps
do you want to use the arduino bootloader in furter time or can this be replaced? can you replace it? have you an ISP programmer? btw you can flash a new bootloader with arduino too.
if you replace it, you can use then the original bootloader from mchp (microchip) and flash it in fc by command tool. have a look into the flowcode folder "tools"
like you posted, you have found the "soft-flasher" progs.
what you want to do? ( must be possible)
a)
use the pinguino bootloader,
develop in pinguino ide, develop in flowcode
upload(download) hex file in pinguino id
uoload(download) hex file in flowcode
b)
use a neutral (HID) bootloader,
develop in flowcode
upload(download) hex file in flowcode
thanks for infos
best wishes
rudi ;-)
mossine
Post by mossine »
hi everyone
hi Mr . Rudi how are you?
i cant use arduino bootloader as you know it's a hard défferent in architecture.
pinguino = PIC microchip
aurduino = ATMEL
yes i have an ISP programmer, i'm going to flash a second PIC18F4550 with bootloader from microchips pdfusb. its work very well with flowcode -MicroC ........
upload(download) hex file in pinguino ide " derect uploading" : this IDE contains an option to upload directly to PINGUINO , it's like pdfusb from microchip ..
thank you so much Mr Rudi ..
hope a nice time
Rudi
Post by Rudi »
hi mohssine, thanks, i am fine, hope you are the same.
let us see, what the point of the not working in downloading it is.
hope we get a solution in this thread :mrgreen:
but I am very confident, that we get this to work.
aurduino = ATMEL
I'm sorry for the confusion.
I meant: if no ISP is programmer for disposal, you can also use an Arduino as ISP programmer to programm the PIC.
info 1
info 2 (picture shows programm an atmel-same you can do for programm a PIC )
mossine wrote: yes i have an ISP programmer, i'm going to flash a second PIC18F4550 with bootloader from microchips pdfusb. its work very well with flowcode -MicroC ........
ok, this is the best solution :)
hope a nice time
ok, let me try to do the same things like you want to do.
i will organcice pinguino ide on a pc, pic 18F2550 is already here.
dont know when i can do this, ( this week ) and let you know how i can help you. hope this is ok.
i am honest, i have not do direct uploading in pinguino IDE, so i hope i have not to much promissed :)
but i think this must go on at this (double) way.
thank you for feedback.
have a nice time :)
best wishes
rudi ;-)
other info
last but not least
mossine
Post by mossine »
hi everyone
hi Mr Rudi ?
thank you for your help .
i hope that's too .. ihop go on at double programming way. PInguino - FLowcode
have a nice and great times .
Rudi
Post by Rudi »
hi Mr Rudi ?
hi mohssine,
..short interim result
I am still in the process ..
..had many problems with the installer..i had installed python 2.7 but the installer said allways, there is no python installed..
then pyUSB stopped all .. and other things.
after several hours .. i get the first thing solved.
the installer is not good.
and pyUSB better to install before install the installer!
i get pyUSB from here: github
now we can go on step by step
the board is ready
the bootloader is ready
the first blinky compile and upload from ide.
now i will start to try what you want to do.
please, it can be duration perhabs to saturday,
i will have a look just in time and try at friday the rest.
now is all installed for a go on.
why this so complicated to install with the installer?
installer is up2date but why this installer do not find pyUSB?
btw witch version 11/12 and which compiler you use?
best wishes
rudi ;-)
Rudi
Post by Rudi »
append..
for flashing i used PicKit3 and Universal zero ziffs for the pinguino Bootloader .
I use the PIC18F2550 20Mhz Version 4x
let me play with this now.
Next post comes with solution or a huge trouble :mrgreen: :mrgreen:
there is only this or that, and even one goal:
it must work.
best wishes
rudi ;-)
Rudi
Post by Rudi »
edit:
made in Flowcode, upload in pinguino IDE
morning.
try in flowcode in linker option
-rb 0xC00
and try direct download this hex file from pinguino ide
get you mistake in python debug shell or all green :wink:
the second part i do not know just in time how we can solve this
ide v11 do not run again after restart without close and open user account and v12 missing compiler files/paths
try later more..
best wishes
rudi ;-)
Rudi
Post by Rudi »
edit:
made in Flowcode, upload in Flowcode by uploader8.py (tool from pinguino IDE)
you need runing python in a stable environment
sugg: use supplementary code for #pragma code
// example: 18F2455 full..(you need only #pragmas  )
#include <p18f2455.h>
/* --- BEGIN: changes required for bootloader ------------------------------ */
extern void _startup (void);        // See c018i.c in your C18 compiler dir
#pragma code _RESET_INTERRUPT_VECTOR = 0x000C00
void _reset (void)
    _asm goto _startup _endasm
#pragma code
#pragma code _HIGH_INTERRUPT_VECTOR = 0x000C08
void _high_ISR (void)
#pragma code _LOW_INTERRUPT_VECTOR = 0x000C18
void _low_ISR (void)
/* --- END: changes required for bootloader -------------------------------- */
edit:
use uploader8.py in flowcode if you want to upload directly
only one parameter is need! the hexfile
$(target).hex
use complety python path if you have python not in the environment path
and call uploader8.py with completly path too
- disable default cfg words / bits to be included in the hex file
- correct linker memory ranges / offset
- custom upload command after successfull project build (this is optional)
let me know how you get on it
happy coding & nice weekend!
Hooray, the weekend is saved.
Hourra, le week-end est enregistré.
:mrgreen:
best wishes
rudi ;-)
btw: this gives me the hint
example
        #pragma config PLLDIV   = 5         // (20 MHz crystal on PICDEM FS USB board)
        #pragma config CPUDIV   = OSC1_PLL2
        #pragma config USBDIV   = 2         // Clock source from 96MHz PLL/2
        #pragma config FOSC     = HSPLL_HS
        #pragma config FCMEN    = OFF
        #pragma config IESO     = OFF
        #pragma config PWRT     = OFF
        #pragma config BOR      = ON
        #pragma config BORV     = 3
        #pragma config VREGEN   = ON      //USB Voltage Regulator
        #pragma config WDT      = OFF
        #pragma config WDTPS    = 32768
        #pragma config MCLRE    = OFF
        #pragma config LPT1OSC  = OFF
        #pragma config PBADEN   = OFF
//      #pragma config CCP2MX   = ON
        #pragma config STVREN   = ON
        #pragma config LVP      = OFF
//      #pragma config ICPRT    = OFF       // Dedicated In-Circuit Debug/Programming
        #pragma config XINST    = OFF       // Extended Instruction Set
        #pragma config CP0      = OFF
        #pragma config CP1      = OFF
//      #pragma config CP2      = OFF
//      #pragma config CP3      = OFF
        #pragma config CPB      = OFF
//      #pragma config CPD      = OFF
        #pragma config WRT0     = OFF
        #pragma config WRT1     = OFF
//      #pragma config WRT2     = OFF
//      #pragma config WRT3     = OFF
        #pragma config WRTB     = OFF       // Boot Block Write Protection
        #pragma config WRTC     = OFF
//      #pragma config WRTD     = OFF
        #pragma config EBTR0    = OFF
        #pragma config EBTR1    = OFF
//      #pragma config EBTR2    = OFF
//      #pragma config EBTR3    = OFF
        #pragma config EBTRB    = OFF
last but not least:
edit(20.05.2016-23:55):
std output
pic18f2550
"setting interrupt vector addresses 0xc00"
so pic18f2550 in FC done with : -rb 0xC00
( if you use the boostc )
Processor: 18f2550
sdcc: Calling linker...
+ C:\pinguino\COMPIL~1\p8\bin\gplink.exe -I"C:\pinguino\compilers\p8\bin\..\share\sdcc\lib\pic16" -I"C:\pinguino\compilers\p8\bin\..\share\sdcc\non-free\lib\pic16"  -sC:\pinguino\v11\p8\lkr\boot4.18f2550.lkr -m  -w -r -o "C:\pinguino\v11\user\source\main.hex"  "C:\pinguino\v11\user\source\main.o"   "libio18f2550.lib" "libdev18f2550.lib" "libc18f.lib" "libm18f.lib" "libsdcc.lib" "libdev18f2550.lib" "libsdcc.lib"
/dvpt/pinguino/git-copy/pinguino-compilers/sources/sdcc/src/pic16/main.c:697 setting interrupt vector addresses 0xc00
std output
pic18f4550
so pic18f4550 in FC done with : -rb 0xC00
(if you use the boostc)
too.
Processor: 18f4550
+ C:\pinguino\COMPIL~1\p8\bin\gplink.exe -I"C:\pinguino\compilers\p8\bin\..\share\sdcc\lib\pic16" -I"C:\pinguino\compilers\p8\bin\..\share\sdcc\non-free\lib\pic16"  -sC:\pinguino\v11\p8\lkr\boot4.18f4550.lkr -m  -w -r -o "C:\pinguino\v11\user\source\main.hex"  "C:\pinguino\v11\user\source\main.o"   "libio18f4550.lib" "libdev18f4550.lib" "libc18f.lib" "libm18f.lib" "libsdcc.lib" "libdev18f4550.lib" "libsdcc.lib"
// edit
