Flowcode V6.3.1.2 freezing when selecting help, about
Running Win7 64bit
Open Flowcode, Select Help, About Flowcode.
The about window is displayed but then have to use Ctrl - Alt - Delete to quit Flowcode as it becomes unusable.
Re: Flowcode V6.3.1.2 freezing when selecting help, about
Hi Martin,
Thanks for letting us know. It doesn't do it for me (win7 64-bit) but certainly something we can look into for you. Does it do it every time you go in?
Hi Ben,
Thanks.
Benj wrote: Does it do it every time you go in?
I does it more often than not.
Not sure if freezing is the correct wording thinking about it.
When selected help, about flwocode then the pop-up window appears:
(127.38 KiB) Downloaded 3687 times
There is no OK to select so just relying on the Esc key.
When Esc key is pressed then there is just a ping sound just like when project options is selected but you click on the flowchart.
The ping is stating you can't do it.
I stated flowcode is frozen since what ever I try and do can't be done because the about screen is still present.
Clicking on the about screen then Esc key makes no difference.
I will check to see if same issue on windows 10
Thanks Martin,
We will investigate, I wonder if it could be a DPI type issue.
Here's how it looks for me.
Hi Ben,
Thanks.
Checked with windows 10 and have the close button so no issues.
Flowcode with the issue has only just been noticed as got a new works laptop and installed flowcode on it.
Let me know if anything you would like me to try.
