PIC16F1779 is not supported , probably because it is a new component.
I need 4 DA outputs
Any advice what to do ?
Thanks and Best regards
Kenrix2
- Flowcode v5 User
- Has thanked: 72 times
- Been thanked: 177 times
Re: PIC16F1779 is not supported
I use PWM connected to an RC filter and an opamp for a variable voltage output. http://www.flowcode.co.uk/mmforums/viewt ... 2cc#p60161
The 16F1779 is not supported by the compiler in Flowcode 6 so currently not possible to support this device.
I am adding it to the list for Flowcode 7 which has a new compiler which does support the device.
