Hello!
PIC12F1501 is not supported.
The PIC12F1501 the PIC16F1503, 1507, 1508 belong to the family. (I do not understand why 12F to prefix this controller ...)
It is possible the PIC 12F1501 support?
Thanks for youre answer!
PIC12F1501 chip support
Forum rules
Re: PIC12F1501 chip support
Sorry these devices are not supported by the PIC compiler in Flowcode 6.
We have a new compiler for Flowcode v7 so I will see if I can get these devices included for you.
There are a number of PIC device families that cross the 12F / 16F boundary. On the modern PIC devices the main difference between a 12F and 16F is the pin count. 12F devices are always 8-pin whereas 16F devices start at 14-pin.
- STibor
- Has thanked: 116 times
- Been thanked: 113 times
Hello!
Thanks for the reply!
Manually you can not create device description files?
A little experimenting, I created 12F1501.fcdx file PIC12F1501.TDF file (registers rewrote the basis of the pic data sheet) PIC12F1501.h file. 16F1503 modifying files.
Unfortunately does not work, ansela, option reg gives the compiler error unknown error.
kersing
- Has thanked: 553 times
- Been thanked: 1081 times
You can create the required files yourself, however Matrix indicated in the past they will not do create the files required for the compiler to support additional chips and they can not provide support if you create them yourself.
― C.S. Lewis
― C.S. Lewis
- STibor
The question is, what type of files?
The question to solve this problem?
If there is an immutable file compiled which prevents the creation of the chip is not dealt with.
If it is not possible to create the chip, I understand.
We can understand that there is no capacity for development.
I believe that the very flowcode7 sale, but the world still has not stopped.
The work can not stop.
kersing
If you want to create the Boost C compiler support files, check the forum for examples, it has been done before, all files required are text files you can create with an editor. You need at least xxx.TDF and xxx.h for Boost C. And when those are ready you need to update a file named map.txt and a file named BoostCPic16.h. When all files for Boost C are ready you need the xxx.fcdx file as well and at that point you should be done. (Apart from fixing issues if you made mistakes)
I've done this myself for Flowcode 5 to support the 16F1455 and 18F24K50/18F25K50 and it is not too difficult, but a lot of work and you might encounter compiler bugs like I did. (I had to buy Boost C with a support contract to get SourceBoost to fix the compiler)
― C.S. Lewis
― C.S. Lewis
- STibor
You solved the problem.
I BoostCPic16.h. file has not been edited with.
Therefore, the end result was bad.
There is hope.
Thank you!
There is hope.
Thank you!
