[Solved] CAN bus int pin selection?
EtsDriver
Has thanked: 345 times
Been thanked: 227 times
Post by EtsDriver »
Hi!
I took a look at the EB018 datasheet, and i see there is pin called *int, but seems that we cannot change it on flowcode when using "software" selections for pins? I have a hardware at hand that has the interrupt pin on some other pin... :O
Re: CAN bus int pin selection?
The component doesn't actually use the INT pin it is just there if you want to use it.
To use the INT signal you could enable an INT interrupt and then connect the INT signal from the CAN board through to the INT pin. Then when the INT interrupt macro fires you can do things like check the CAN IC for incoming messages.
EtsDriver
Post by EtsDriver »
Oh, nice to know! :)
