TK-II-OS_V1_6.c(540:23): error: unknown identifier 'RBIE'
TK-II-OS_V1_6.c(540:23): error: invalid operand 'RBIE'
TK-II-OS_V1_6.c(540:18): error: failed to generate expression
TK-II-OS_V1_6.c(540:18): error: invalid operand '<<'
TK-II-OS_V1_6.c(540:12): error: failed to generate expression
TK-II-OS_V1_6.c(578:24): error: unknown identifier 'RBIE'
TK-II-OS_V1_6.c(578:24): error: invalid operand 'RBIE'
TK-II-OS_V1_6.c(578:19): error: failed to generate expression
TK-II-OS_V1_6.c(578:15): error: invalid operand '~(1 << ( RBIE))'
TK-II-OS_V1_6.c(578:12): error: failed to generate expression
TK-II-OS_V1_6.c(6217:26): error: unknown identifier 'RBIF'
TK-II-OS_V1_6.c(6217:26): error: invalid operand 'RBIF'
TK-II-OS_V1_6.c(6217:21): error: failed to generate expression
TK-II-OS_V1_6.c(6217:21): error: invalid operand '<<'
TK-II-OS_V1_6.c(6217:16): error: failed to generate expression
TK-II-OS_V1_6.c(6217:57): error: unknown identifier 'RBIE'
TK-II-OS_V1_6.c(6217:57): error: invalid operand 'RBIE'
TK-II-OS_V1_6.c(6217:52): error: failed to generate expression
TK-II-OS_V1_6.c(6217:52): error: invalid operand '<<'
TK-II-OS_V1_6.c(6217:47): error: failed to generate expression
TK-II-OS_V1_6.c(6217:16): error: invalid operand '& '
TK-II-OS_V1_6.c(6217:47): error: invalid operand '& '
TK-II-OS_V1_6.c(6217:34): error: failed to generate expression
TK-II-OS_V1_6.c success
So here's what I see in the FCD file at this time. Can someone describe how I would modify this to reflect the 1847's needs as pertaining to the PortB interrupt on change?
[PORTB]
Name="PORT"
FlagReg=
FlagBit=
HandlerCode="#ifndef MX_INTHANDLER_intcon_RBIF\n#define MX_INTHANDLER_intcon_RBIF\nchar mxtmp;\nif (ts_bit(intcon, RBIF) && ts_bit(intcon, RBIE))\n{\n\t#ifdef USE_FLOWCODE_ICD\n\t\textern char ICD_Interrupt_Enable = 1;\n\t#endif\t\n\tFCM_%n();\n\tmxtmp=portb;\n\tcr_bit(intcon, RBIF);\n\t#ifdef USE_FLOWCODE_ICD\n\t\textern char ICD_Interrupt_Enable = 0;\n\t#endif\t\n}\n#else\n#warning "This interrupt has previously been enabled, so the macro <%n> may never get called."\n#endif\n"
UseExplicitHandlerCode=1
UseExplicitEnableCode=1
EnReg=
EnBit=
EnableCode="st_bit(intcon, RBIE);\n"
DisableCode="cr_bit(intcon, RBIE);\n"
OptCnt=0Michael
