edit/duplicate makro - return type not show/not correct type
Rudi
Has thanked: 493 times
Been thanked: 187 times
Post by Rudi »
hi guys
sorry for this, too.
think have found the second small bug, that had annoyed me in the past too
Now I could catch him at last: here you go:
create an empty makro with string return
you will see this correct line if you export the makro:
<return name='Return' type='T8' description='' isconst='0' isinit='0' usrinit='""' setinit='' >
<array size='20' />
bug1: if you try to edit this makro, the return type is not show again,
you do not know, what the makro is return just in time ( in edit mode )
now duplicate the makro two times and change the return
a) one times:
to byte
you will see this line if you export the makro
we have only a byte - line with the array size is the bug2
<return name='Return' type='u8' description='' isconst='0' isinit='0' usrinit='""' setinit='' >
<array size='20' />
this relict of "<array size='20' />" makes the problem then in the call makro like you see here:
and in c code the return is missing
and works with the pointer technic from the preview string return as parameter..
( see to the last with create a new macro with return byte )
void FCM_cpyReturn_String_change2byte(MX_UINT8 *FCR_RETVAL, MX_UINT16 FCRsz_RETVAL);
to do:
clean the line with <array size='20' />
b) second times:
no return
we have no return - line with the array size is the bug2
<return name='Return' type='v0' description='' isconst='0' isinit='0' usrinit='' setinit='' >
<array size='20' />
we have no return now selected, but
this relict of "<array size='20' />" makes the problem bug3 then in the call makro like you see here:
to do:
same like before,
FYI:
with certain compiler flags stops the compiler because wrong return sometimes.
btw:
a new created makro with return byte show correct this line
<return name='Return' type='u8' description='' isconst='0' isinit='0' usrinit='0' setinit='' />
</flowline>
and shows in c code correct:
MX_UINT8 FCM_newByteReturn();
thanks
best wishes
rudi ;-)
Has thanked: 481 times
Been thanked: 699 times
Re: edit/duplicate makro - return type not show/not correct
Hi Rudi
Thanks for your detailed report.
I'll add it to our list.
Leigh
