Conversion FC5/6 to Flowcode 7 that contains C code
Before compiling Flowcode V7 that has been loaded with Flowchart from Flowcode V5 or Flowcode V6 you must convert C code from BoostC to XC8 as that is what's shipped with Flowcode V7
In Boost C lower case is used for register and uppercase for bits.
In XC8 Upper case is used for both.
Examples
BoostC  (Up to FC6)         XC (FC7)
osccon = 0x70;              OSCCON = 0x70;
st_bit(iocap,IOCAP3);     st_bit(IOCAP,IOCAP3); or set_bit(IOCAP,IOCAP3);
If bit is a NOT bit, for example to enable weak pullups the register bit could have a bar above:
Option Register.jpg (8.01 KiB) Viewed 12204 times
Then you need to place a lower case n preceding the bit name.
for example to enable weak pull-ups on 16F1825 you will need to use:
clear_bit(OPTION_REG,nWPUEN); or  cr_bit(OPTION_REG,nWPUEN);
If I find any more examples I will post them.
millsk3
Has thanked: 1 time
Re: Conversion FC5/6 to Flowcode 7 that contains C code
Post by millsk3 »
I am learning how to use Flowcode 7 using the book: Create 30 PIC Microcontroller Projects with Flowcode 6. Most of the projects work without problems and the only ones that don't work are those with C Code.
I have no knowledge of C Code, so could someone help me to convert the C Code so it works in Flowcode 7. The one I am looking at is : FCV_FROMTABLE = ATF [FCV_POSITIONINTABLE] ;
It would be good if Matrix could provide a list of examples for the commonly used C Code or even an update of the files which support this book.
Thank you.
Ken
Hi Ken,
It looks like the formation of a lookup table in C since FCV is just FlowCode Variable.
So it was just retreving a value from an array.
That's what the square brackets mean - [] = array
Since from Flowcode V6 there is a lookup table component you can use that instead of C code.
For help on lookup table component see here
Just to make sure if you post your flowchart I can take a look.
millsk3
Has thanked: 1 time
Post by millsk3 »
Martin,
Thank you very much. I have substituted the lookup table as you suggested and it now works properly, this also allows me to use the simulation function.
Ken
Hi Ken,
Glad your all sorted.
Thanks for letting us know.
