Pin Selection for Internal CAN
eSYS.co
Post by eSYS.co »
Hello Flowcode 7 friends,
I have a problem with the set of input and output pins for the internal CAN.
There are at "Connections"> TX pin and RX pin.
I can open here "Edit properties" and set checkbox "writeable".
When i dobble click "$ PORTA," the grafical Pin editor opened.
The preselected pin is always "RA0" (for TX and RX).
No change is possible!
How does it work?
How can I assign the correct pins?
Thanks for your help!
PS: Controller is "dsPIC33EP64MC503"
Re: Pin Selection for Internal CAN
Are you using the "CAN (Internal, MCP2515)" component in the "Comms" menu? This seems to be working ok for me.
The "CAN" in the "Peripheral CAL" section of the "Tools" menu does seem to have a problem, but I think you should be using the one in the "Comms" menu.
eSYS.co
Post by eSYS.co »
Yes that is correct. I use the can from the "comms" menue.
Handle = Can1
Type = can (internal, mcp2515)
But i don't can change the connection pins.
There Show always
TX Pin $PortA.
RX Pin $PortA.
Best regards,
Andreas
EtsDriver
Has thanked: 345 times
Been thanked: 227 times
Post by EtsDriver »
eSYS.co wrote:Hello Flowcode 7 friends,
How does it work?
Oh i see:
(173.4 KiB) Downloaded 2349 times
The ds33EP64MC503 has RP pins, RemappablePeripherals? Peripheral Pin Select (PPS)?
Matrix team take a look to 175-177 pages of this devices datasheet:
http://ww1.microchip.com/downloads/en/D ... 00657H.pdf
OFFtopic: This micro seems to be a great little controller, might implement it to something if FlowcodeV7 gets these Remappable pins to work fine with all those supported communications? :)
Thanks for letting us know of the problem. I have tracked it down to a missing definition in the chip definition file which has now been fixed.
To apply the fix simply extract the files from the archive into your "Flowcode 7/FCD/PIC16" folder and then restart Flowcode.
PIC16.zip
(108.88 KiB) Downloaded 383 times
Let me know how you get on.
eSYS.co
Post by eSYS.co »
Thank you for the zip file.
Now i can set the Input and Output Pins for the CAN_Driver. :D
Whren i compile the Code i become the following error message:
Is there an additional problem ?
  • C:\Program Files (x86)\Flowcode 7\CAL\/PIC16BIT\PIC16BIT_CAL_CAN.c: In function 'FC_CAL_Internal_CAN_Init_1':
    C:\Program Files (x86)\Flowcode 7\CAL\/PIC16BIT\PIC16BIT_CAL_CAN.c:200:4: error: 'RPINR26BITS' has no member named 'C1RX'
    Error returned from [xc16-gcc.exe]
    C:\Program Files (x86)\Flowcode 7\compilers\pic16\batchfiles\pic16_C30_comp.bat reported error code 1
Thanks for help.
Thanks for letting us know. The "C1RX" should be "C1RXR".
I have fixed the problem in the chip definition file. You simply have to download the file and copy it to the "Flowcode 7/FCD/PIC16" folder before starting Flowcode and the changes will be loaded.
33EP64MC503.fcdx
(29.49 KiB) Downloaded 340 times
|Let us know how you get on.
I may have also found another bug to do with the fact that the device does not have DMA memory for the CAN buffers.
If you get a linker compile error saying there is not enough memory then this should hopefully solve the issue.
Simply place the attached file into your "Flowcode 7/CAL/PIC16BIT" folder and then the compilation should succeed.
PIC16BIT_CAL_CAN.c
(68.28 KiB) Downloaded 412 times
EtsDriver
Post by EtsDriver »
Hey!
The dsPIC33FJ256GP710 and 710A version of this chip seems to have similar issues with internal CAN pin selections? Even after applying the "fixing" pic16.zip files? Might be more internal selections problems like SPI side but didnt have time to check everything out now.
http://www.microchip.com/wwwproducts/en ... J256GP710A
Many thanks for letting us know, seems we missed these devices on the last pass through as well as a few others.
The attached definition files have now been updated with the correct CAN pin definitions.
PIC16_CAN.zip
(258.12 KiB) Downloaded 382 times
Lord Grezington
Flowcode V4 User
Has thanked: 29 times
Been thanked: 30 times
Post by Lord Grezington »
Hello Ben
I have the same problem using FC6 attempting to re-map the pins when trying to use the internal ECAN on the 33EP32MC504. Please can you send me an updated file so that the mapping works as required?
The v7 updated FCD files and CAL C file should be compatible with v6. Make a backup of your files first just in case there are any problems.
Let us know if not and we will investigate.
